How to Un-seize a Piston: British Seagull Outboard Engine + Change Impeller, Gearbox Oil Seal & Carburetter
3,987
16
Posted
Introduction: How to Un-seize a Piston: British Seagull Outboard Engine + Change Impeller, Gearbox Oil Seal & Carburetter
How to un-seize a rusty piston using heat and dismantling fluid.
 Fully seized 2 stroke Seagull Outboard Engine Restored and Running. Gearbox removal and seal replacement, Water pump / impeller change and carburetor repaired. The principles are the same for most seized piston engines, be it a lawnmower, motorcycle, car or outboard motor as shown here.
Hope you find this video useful. Please remember to share and like it, this really does help more people to find my videos. I look forward to reading your comments. Kind regards   Andrew
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
3 Comments
My father showed me a truck to free stick cylinders with less brute force that can break the piston rings.
Break all the porcelain out of a spark plug. Tap and thread the remaining metal bit and put a grease zerk fitting in it. Install in the engine and he used a brand new lever style grease gun. Start pumping grease to it. At 3000 psi and being grease it will pop right loose.
