This instructable will tell you how to unclog your pores and clear acne in just a few simple steps!
This is a very low-maintenance method that requires only a few items, patience, and a tiny bit of will.
This method involves four major steps:
Ridding your surface skin of oil and dirt
Opening your pores for proper exfoliation using steam
Exfoliating to remove oil and dirt trapped in your pores
Applying 2.5% Benzoyl Peroxide to cleanse deep inside your pores and rejuvenate them.
The reason this works so well is because the steam opens your pores allowing you to clean them better, while the facewash removes surface dirt/oil, the exfoliant removes the dirt/oil in your pores, and the Benzoyl Peroxide deep cleans while rejuvenating your pores.
I used to have seriously bad acne that drove me crazy. I felt like one giant zit and that's all people saw when they looked at me. This method has worked wonders for my face so far, even after everything else I've tried has failed. It's easy and leaves my face feeling clean, fresh, and rejuvenated. =)
Step 1: What You'll Need
Exfoliating facewash - Optionally containing salicylic acid for more benefits
2.5% Benzoyl Peroxide Cream
Small cooking pot
Water
Towel
Hot pot pad, trivet, or extra towel
Note: Do not use Benzoyl Peroxide stronger than 2.5%. Studies have shown that 2.5% BP is just as strong as 10%, but much less irritating to the skin.
Step 2: Preparing Your Face for Treatment
Note for guys: You may want to consider shaving first, as it greatly helps the treatments in cleansing the pores.
Step 3: Opening Your Pores for Treatment
Remove the pot from the stove and set it on a towel, hot pot pad, or trivet.
Drape the towel over your head and place your head above the pot.
Have a seat and allow the steam to unclog your pores for 5 minutes. You may listen to music to pass the time, if you'd like.
Careful - Do not touch the pot as it is hot. Do not put your head above the stove. Do not set the pot on a surface unprotected from heat.
Step 4: Exfoliating
Step 5: Applying the Benzoyl Peroxide
Apply a very small amount of 2.5% Benzoyl Peroxide to your finger tip. Very gently rub it on to the affected area (~1 in. around every blemish). You may need to apply it to your entire face.
Rub it in a circular motion until it becomes tacky and your finger starts to stick to your skin.
Once this occurs, start applying once again to a different area. This ensures proper absorption into the pores.
After you've applied it to all affected areas, you're done!
Step 6: For Best Results
To aid in pore rejuvenation and cleansing, three to four days after performing this method you should exfoliate normally.
For example, if I perform this face cleanse on Saturday, then I would exfoliate normally on either Tuesday or Wednesday, and then perform this cleanse again the following Saturday.
Try not to touch your face as the oils from your fingers may assist in clogging your pores.
Poor diet also attributes to acne. Lots of sugar and caffeine has been known to aid in the clogging of pores. A poor functioning liver may also cause acne as it cannot properly process the hormones in your body leading to an overproduction of oil in the skin. You may want to look into performing a liver/stomach cleanse.
Drink lots of water to help your skin stay healthy. Zinc has been shown to help reduce acne. You may want to consider taking a multi-vitamin containing zinc if you don't already.
Be sure to wash your face once a day with a mild, preferably triclosan medicated, facewash. Washing more than once a day may irritate the skin, so if you must, try to only rinse your face and pat dry.
Visit Our Store »
Go Pro Today »
This product works very well unclogging pores, getting rid of of dead skin and making the skin smoother, no new pimples to leave MORE dark spots. All of which make the skin look and feel much better/fresher. Remember only the skin in contact with the product is helped. Heaping it on wastes your money and this hard to find product!
A few cautions... 1-keep drinking plenty of water to keep your body hydrated, it's natural repair function working well and your skin fresh, 2-This product dries the skin out, use a good moisturizer/moisturizing sunscreen.
For me it is essential to use the Shielo Scrub at night to kickstart the natural repair cycle. It's a little tingly, nothing really harsh though. Skip TWO nights and REPEAT which helps you get 2-3 treatments in a week as recommended.
I also suggest using an exfoliating scrub 3 or 4 days after performing the steam facial cleanse.
But I prefer root beer =D
I only recently stumbled upon this method and I wish I knew it when it mattered; high school. =D
