How to Unlock a Bathroom Lock If Your Sibling Has It Locked
Published
Introduction: How to Unlock a Bathroom Lock If Your Sibling Has It Locked
About: I take things apart, building new things with those parts, come up with my own way of building things, and I invent new simple things, such as simple robots, or just toys. I also love playing my drum set!
     Have you ever needed to get into the bathroom and you can't get in because one of your siblings locked it?, If so definitely read his instructable. Right when I see that the door is locked I think "Jury-Rig it!," and so should you.
     Most bathroom locks are very simple unlike the lock to your front door, most are just simple turning locks on the door knob. So if  that's simple it must be pretty easy to get in once you have an idea. That's why I made this instructable, to show you the way I figured out how to get into a locked door. Although this only works on certain kinds of locks.
Step 1: What You Can Use
To get into a bathroom lock you can use almost anything including: change in your pocket (quarter, penny, nickle, or even a dime), or maybe a paperclip in your drawer or pocket. If you don't have any of that stuff then you can even use your belt!
Step 2: How to Unlock the Door
To unlock the lock you have to turn the object your using side ways, push it in, and turn, you'll see in the pictures, they'll help you.
Step 3: Lock Master
Now you know how to open a bathroom door if your sibling is being annoying and purposely locking you out of the bathroom.
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    7 Discussions
    How would u do it if there is no key hole on the door knob on the outside? How would u unlock it?
    Actually, it works with ALL slot-type locks. Hole-type locks are only a little bit harder, needing a flathead screwdriver that fits into the hole to turn the lock (still the same internal mechanism). The only difference between the two is how quickly you can open them.
