Introduction: How to Unroll & Roll Fire Hose & Take in and Out of Service
Picture of How to Unroll & Roll Fire Hose & Take in and Out of Service
I will be showing a step by step to unroll and roll fire hose
Step 1: Pick Up Hose
Picture of Pick Up Hose
Step 2: Grab Hose Male Coupler Facing Forward
Picture of Grab Hose Male Coupler Facing Forward
Step 3: Two Fingers Under First Lay of Coupler
Picture of Two Fingers Under First Lay of Coupler
Step 4: In a Swinging Motion With Hose (ring Finger and Little Finger Holding Second Lay
Picture of In a Swinging Motion With Hose (ring Finger and Little Finger Holding Second Lay
Step 5: Swing in a Bowling Motion
Picture of Swing in a Bowling Motion
Step 6: Release Little Finger and Ring Finger
Picture of Release Little Finger and Ring Finger
Step 7: If Hose Doesn't Unroll Completely, Unroll Hose and Make Sure It Is Lying Flat
Picture of If Hose Doesn't Unroll Completely, Unroll Hose and Make Sure It Is Lying Flat
Step 8: To Correctly Roll an Inservice Hose Starting With the Male Coupling Fold Over Top of Hose and Continue Rolling Motion
Picture of To Correctly Roll an Inservice Hose Starting With the Male Coupling Fold Over Top of Hose and Continue Rolling Motion
Step 9: After Rolling Hose Lay Hose on Side
Picture of After Rolling Hose Lay Hose on Side
Step 10: Stepping on Hose Roll Make Sure Hose Is Flat
Picture of Stepping on Hose Roll Make Sure Hose Is Flat
Step 11: If Hose Is Out of Service
Picture of If Hose Is Out of Service
Step 12: Unroll Hose
Picture of Unroll Hose
Step 13: Make Sure Hose Is Completely Flat
Picture of Make Sure Hose Is Completely Flat
Step 14: Roll Hose With the Female Coupling on the Inside
Picture of Roll Hose With the Female Coupling on the Inside
Step 15: Lay Hose on Side
Picture of Lay Hose on Side
Step 16: Stand on Hose Making Sure Hose Is Flat
Picture of Stand on Hose Making Sure Hose Is Flat
Step 17: When Taking a Hose Out of Service and Rolling Backwards You Must Document Hose Number That Was Taken Out of Service
Picture of When Taking a Hose Out of Service and Rolling Backwards You Must Document Hose Number That Was Taken Out of Service
Step 18: Then Replace the Out of Service Hose With a Functioning in Service Hose
Picture of Then Replace the Out of Service Hose With a Functioning in Service Hose
Step 19: If You Are Interested in Learning How to Roll Hose Please Contact Your Local Fire Department
Picture of If You Are Interested in Learning How to Roll Hose Please Contact Your Local Fire Department
Step 20: Maybe I Can Teach You How to Roll Hose
seamster (author)2016-03-28
This was very interesting. Thanks for sharing the process!
About This Instructable
2,798views
1favorite
More by ColeL4:How to unroll & roll fire hose & take in and out of service
Add instructable to:
