How to Upload Videos to YouTube using iMovie
 by Engl313UA
These instructions are designed to teach you how to upload high quality videos from iMovie HD 7 to YouTube. Go to this link for complete video instructions: http://www.youtube.com/watch?v=hoDsUeqk2bc
Step 1: Prerequisites
• You have transferred the video files from your camera to the computer
• You have created a YouTube account
• iMovie HD 7 is installed on your Mac OSX 10.6 computer
Step 2: Importing Raw video into iMovie HD 7
Step 1.tiff
Step 2.tiff
Step 3.tiff
1. Open iMovie
2. Click on Create New Project
3. Title your project
     • Under video format select DV Widescreen
4. Click create
5. Open the folder containing the raw video using a Finder window
    • Drag the file(s) into one of the gray tiles on the right side of the iMovie interface
Step 3: Creating your .MOV output file
Step 4.tiff
Step 5.tiff
Titling your movie
1. Click on the editing option on the bottom right of the iMovie window
2. Click on the Titles box on the top right of the iMovie window
3. Choose a title appearance from the dialog box
4. Type your title into the text box
5. Click add located below the text box
Step 4: Sequencing the Raw Videos
Step 6.tiff
1. Click on the clips button
2. Drag clips into the time line box in the desired order
Step 5: Selecting the Video Output Options
Step 7.tiff
Step 8.tiff
Step 9.tiff
Step 9.tiff
Step 10.tiff
Step 11.tiff
1. Click on the share option at the very top of the screen
2. Select quicktime from the drop down menu
3. Select Expert Setting from the Compress Movie drop-down menu
4. Click Share
5. Click on options in the Save exported file as. .. box
6. Click settings under the video menu
    • Set compression type to H.264
    • Set frame rate to 30
    • Set key frames to every 30 frames
    • Set data rate to Restrict to 5000kbits /sec
    • Set optimization for streaming
    • Click ok
7. Click Size under the video menu
    • Select 1280x720 HD
    • Check the deinterlace source video box
    • Click ok
8. Click settings under the sound menu
    • Set format to AAC
    • Set channels to stereo
    • Set rate to 44.100 kHZ
    • Click on Show advanced settings
    • Set quality to normal
    • Set encoding strategy to average bit rate
    • Set target bit rate to320 kbps
    • Click ok
9. Click ok under the movie settings menu
10. Click on save under the save exported file box to start exporting raw video
Step 6: Importing Video to YouTube
Step 12.tiff
Step 13.tiff
Step 14.tiff
1. Log into your YouTube account
2. Select upload at the top right corner
3. Click on upload video
4. Open a Finder window containing the newly created .MOV video
5. Drag .MOV video to the dashed rectangle on Youtube upload screen
6. Click ok
7. Select desired settings under the video information and privacy setting boxes
8. Click save changes below the license selection boxes
9. Copy the URL listed under sharing options
10. Open a new browser window and paste the URL into it
Step 7: Video of Process
Follow this link for a video of the instructions: http://www.youtube.com/watch?v=hoDsUeqk2bc
GrimSweeper says: Oct 17, 2011. 1:35 PM
Having the pre-requisites as a separate step was somewhat odd; it would be better if they were included in something that is not a step. The steps are clear, but can be confusing for those with no knowledge beforehand of the programs. I feel Step Five could be split up for added clarity as well. Finally, Step 3's subtitle is either unnecessary, or should be the title of Step 3 itself, otherwise it breaks up the flow a bit. On the nitpicky side of things, in the images for Step 5, one picture seems to have been put in twice. Otherwise, the instructions are well-put and helpful.
english3132011 says: Oct 13, 2011. 7:39 AM
This is a good tutorial for uploading iMovie to YouTube. Just to nitpick, in addition to what others have commented upon regarding wordiness and a few select problems (which you have corrected), it might be helpful to separate some of the sub-step instructions in order to space out the information. It seems a little congested at times. Specifically, I am referring to the somewhat long Steps 5 and 6. Otherwise, great job!
Ashton Brown
ENGL313, Fall 2011
englishexcel313 says: Oct 12, 2011. 6:53 PM
the instructions were good enough for me to able to do on my own, but I can see how a person, that does not have any background with this stuff, might have a tough time.
english3132011 says: Oct 12, 2011. 4:31 PM
I thought that overall your instructions were very helpful. I have to agree with some of the additional comments, Step 1: "Assumptions" is a bit confusing but is only a minor adjustment. "Pre-Requisites" would work better here or "Prior to Starting." Otherwise, the pictures are very helpful. They clearly direct first-time users in the right direction. Overall, great job. - Ryan Antisdale
EngUA313 says: Oct 12, 2011. 3:10 PM
This was a good tutorial, I feel like the images did help. I think the only problem might be that I feel like you may have to have some background knowledge, not made for beginners really but overall, good job! -Maryam N.
cjmueller says: Oct 12, 2011. 8:23 AM
Overall, it is a pretty good tutorial. I agree with the other comments about the "assumptions" section. Also, I would consider including comments for your images. It is fairly easy to do through instructables.
scheinma says: Oct 11, 2011. 12:29 PM
Great instructions. A little wordy and remember that users have to backtrack some.
dbezies says: Oct 11, 2011. 8:36 AM
Your instructions were helpful overall. But i agree with the other comment, change the first step "Assumptions" to something else, maybe "Before you start" or "Pre-requisites". otherwise very well done.
KH2323 says: Oct 11, 2011. 7:14 AM
Pretty helpful. Step 1 "Assumptions" is weird. Maybe "Pre-Requisites"?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
