How to Upload Videos to YouTube using iMovie by Engl313UA
Step 5: Selecting the Video Output Options
Step 7.tiff
Step 8.tiff
Step 9.tiff
Step 9.tiff
Step 10.tiff
Step 11.tiff
1. Click on the share option at the very top of the screen
2. Select quicktime from the drop down menu
3. Select Expert Setting from the Compress Movie drop-down menu
4. Click Share
5. Click on options in the Save exported file as. .. box
6. Click settings under the video menu
    • Set compression type to H.264
    • Set frame rate to 30
    • Set key frames to every 30 frames
    • Set data rate to Restrict to 5000kbits /sec
    • Set optimization for streaming
    • Click ok
7. Click Size under the video menu
    • Select 1280x720 HD
    • Check the deinterlace source video box
    • Click ok
8. Click settings under the sound menu
    • Set format to AAC
    • Set channels to stereo
    • Set rate to 44.100 kHZ
    • Click on Show advanced settings
    • Set quality to normal
    • Set encoding strategy to average bit rate
    • Set target bit rate to320 kbps
    • Click ok
9. Click ok under the movie settings menu
10. Click on save under the save exported file box to start exporting raw video
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
