Introduction: How to Use Car Vacuum Cleaner or Tyre Inflator at Home
Things Required
DC Power Supply Driver 12V 10Amp 120W used for CCTV - ( INR 600.Rs )
Plastic Enclosure (Electrical Switch Box) - ( INR 120.Rs )
Car Cigarette Lighter Socket 12V - ( INR 80.Rs )
3 Pin Power Plug Cable - ( INR 50.Rs)
Terminal 2 Position Wall Plate - (INR 10.Rs)
12V PC Fan - ( INR 30.Rs )
Mini voltmeter tester Digital voltage (Optional) Used as i had it 1 laying around. ( INR 200. Rs )
Totally you can get Everything for around ( INR 1,000 Rs) ( 15 $ )
Step 1: 12V 10Amp 120W DC Power Supply Driver Used for CCTV
Step 2: Plastic Enclosure (Electrical Switch Box)
Step 3: Car Cigarette Lighter Socket (12V)
Step 4: PC Fan 12V
Step 5: Mini Voltmeter Tester Digital Voltage (Optional)
Step 6: Power Plug Cable 3 Pin
Step 7: Terminal 2 Position Wall Plate (can Be Used for Other Expansion Purposes)
Step 8: Explanation on Parts & Inside View
Step 9: Explanation on Parts & Inside View
Step 10: Sketch
2 Comments
Great instructable, I've been looking for something to serve this very purpose.
Do you find that the placement of the fan has much effect on heat dissipation?
Hi, thank you im glad that i helped you :) .& regarding the fan i have mounted it little bit higher from ground level of box given down below with rubber spacers... & i suggest you to add few more holes on the top cover of the box.
