How to Use ESP8266 With PCF8574 - 4 Input and 4 Output
6,099
50
8
Posted
Introduction: How to Use ESP8266 With PCF8574 - 4 Input and 4 Output
How to increase the number of I/O pins on the ESP8266 using the PCF8574. This example will use four buttons (as inputs) and four relays (as outputs) and only one PCF8574 chip. The four pins of the PCF8574 chip will be set as inputs and four pins as outputs. In this example I will use NodeMCU but it works well on ESP8266-01. In this tutorial I will also show you, how to use jQuery AJAX with ESP8266. The software for the ESP8266 was written in the Arduino IDE. NodeMCU, ESP8266 is a very good solution for IOT (Internet of things).
This article can also see here:
How to use ESP8266 with PCF8574 - 4 input and 4 output
Step 1: Components
Step 2: Schematic
Step 3: Software
To use PCF8574 on ESP8266 I use this library pcf8574_esp.
This number "0b00111000" is the address of the PCF8574 expander.
The last 3bit (0b00111000) can be set using address pins A0, A1, A2. Thanks to which
we can connect more expanders to the same I2C bus. In this tutorial, I use an interrupt to
notify the ESP8266 microcontroller that it has made a change in the input state.
PIN_INT defines interrupt pin D5.
	PCF857x pcf8574(0b00111000, &Wire);
	#define PIN_INT D5
	#define PIN_SDA D1
	#define PIN_SCL D2
Configure WIFI connection and HTTP server. Before you upload the software to ESP8266 setup
your WiFi connection. The HTTP server allows us to control relayers using a web browser.
	//WIFI i server HTTP
	ESP8266WebServer server(80);
	#define WIFI_SSID ""
	#define WIFI_PASSWORD ""
	#define HOST_NAME "onoff"
In this code fragment we setup the i2c bus and our PCF8574 I/O expander. Using this "pcf8574.begin (0xF0)"
we set 4 pins in high as inputs and 4 pins in low as outputs.
  Wire.pins(PIN_SDA, PIN_SCL);//SDA - D1, SCL - D2
  Wire.begin();
  pinMode(PIN_INT, INPUT_PULLUP);
  pcf8574.begin( 0xF0 ); //4 pin input, 4 pin output
  pcf8574.resetInterruptPin();
This part of the code is responsible for handling the PCF8574 interrupt. If PIN_INT is low,
our expander notifies us of a change in input. After reading the pin values from the expander,
PIN_INT will return to high.
 if( digitalRead(PIN_INT)==LOW ){
    delay(50);
    byte b = pcf8574.read8();
    Serial.println( "INT: " + String(b));
    byte keys = ((~b) >> 4) & 0x0F;
    if( CheckKey(keys, 0) ){
      Serial.println( "KEY 0");
      SW_toggle(0);
    if( CheckKey(keys, 1) ){
      Serial.println( "KEY 1");
      SW_toggle(1);
    if( CheckKey(keys, 2) ){
      Serial.println( "KEY 2");
      SW_toggle(2);
    if( CheckKey(keys, 3) ){
      Serial.println( "KEY 3");
      SW_toggle(3);
Download source code: ESP8266_PCF8574.ino
Step 4: ESP8266 Firmware Upload With Arduino IDE
  1. Select your board Tools -> Board -> NodeMCU 1.0(ESP-12E Module)
  2. Press the upload button
  3. After uploading the software in Serial Monitor you can see the IP of your ESP8266.
Step 5: The End
Take IP from Serial Monitor and type in web browser. You will see the control panel of the ESP8266, thanks to which you can control the relays. You can also control the state of the relays using the buttons. If you turn on the relay with the physical button, the state of the relay will change automatically. This is possible thanks to the use of jquery ajax. The below piece of code that is responsible for it.
  //BEGIN: AJAX ------------------------------------------
  html += "<script src='https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js'></script>\r\n";
  html += "<script>\r\n";
  html += "function ajax_read(){\r\n";
  html += " $.ajax({\r\n";
  html += "    url: 'state', \r\n";
  html += "    success: function(result){\r\n";
  html += "      $('#res').html(result);\r\n";
  html += "    }\r\n";
  html += "  }\r\n";
  html += " );\r\n";
  html += "}\r\n";
  html += "function check() {\r\n";
  html += " ajax_read();\r\n";
  html += " setTimeout(function(){ check(); }, 1000);\r\n";
  html += "}\r\n";
  html += "check();\r\n";
  html += "</script>\r\n";
  //END: AJAX ------------------------------------------
wwwGoogle pluseTwitter
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
8 Comments
wel done. As your PC8547 link shows, the individual chip often is more expensive than the ready made module. The cheapest I saw the module I think was USD 1.15.
However... it can be cheaper. One could also buy an I2C LCD module. Those modules are supposed to be soldered to the back of an LCD to make it I2C operational...and those are also based on an 8547 chip.
Such modules cost 0.55 USD
https://www.aliexpress.com/item/Free-Shipping-IIC-...
It is true that the same chip, and is much cheaper!
even 49 cts ;-)
https://www.aliexpress.com/item/IIC-I2C-Interface-LCD1602-2004-LCD-Adapter-Plate-for-Arduino-Free-Shipping-Dropshipping/1362338996.html?spm=2114.10010108.0.0.lYD4QN&scm=1007.12873.42117.0&pvid=32df182f-b1e6-4c92-8df0-4910084175f7&tpp=1
i'm trying to understand why not using 2 ESP's and connect them. Isn't that easier? It differs about $1 in price.
You could do that, but then it would be hard to use the 4 buttons and 4 relays from 1 program
Exactly, you can use two ESP but if you want one program to handle this then the method is easier.
Excellent, just what I needed and really well explained. Thank you!
Thanks for comment
