How to Use IR With Arduino
Published
Introduction: How to Use IR With Arduino
About: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths caused by my projects.
This instructable will show you how to use an IR remote and Reciever with Arduino.
I got a kit from GearBest that has everything in it that you will need for this project, also this kit is very good for beginners and i would recommend you check it out here
The parts you will need are:
1) IR Reciever
2) IR Remote (any kind will do)
3)Wires
Step 1: Connect Everything
This is super simple to do just fallow the picture and you will be golden!
Step 2: Program It
DOWNLOAD THE LIBRARY "IRremote"
Use the example code "IRRECORD" for this
Step 3: Your Done!
You should now get a read out on your serial port!
If you have any questions leave them in the comments, thanks
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Like most projects that I have seen the sensor is connected in the simplest way. If you check the data sheet you will find just a slightly more complicated circuit. My testing indicates these circuits ( for just a few pennies ) significantly improve accuracy. Author, why not check the data sheet and see what you think.
    Thank you @russ_hensel, I will look into it!
