How to Use Sugru to Make ARO Rubber Wall
2,014
4
Posted in WorkshopMolds-and-casting
Introduction: How to Use Sugru to Make ARO Rubber Wall
Follow those steps to make ARO rubber wall from Sugru
Step 1: The Stuff You Need
See image
Step 2: Apply the Release Agent
    We can use dish soap
    Apply a large amount of dish soap on the mold base
    Apply the dish soap only at the channel area
    Step 3: Add Rubber Wall Stiffener to the Mold
    Make sure the stiffener bonding surface is dry
    Step 4: Apply Sugru to the Mold Base
    Try to push Sugru into the channel
    Use paper towel to dry the Sugru bonding surface only
    Do not wipe away the dish soap on the mold base
    Step 5: Compression Mold Part 1 and Base
    Compress the Sugru with both mold pieces
    Use your thumb and index finger to push Sugru into the mold
    Make sure the stiffener is flushed to the surface
    Use craft knife to cut away extra Sugru
    Step 6: Remove Mold Base and Clean Up
    Remove mold base
    Step 7: Remove Molded Piece From the Mold
    Remove molded piece with stiffener attached from the mold
    Let it sit for 24 hours
    Step 8: Post Mold Cure Process
    Remove extra part of stiffener base
    File the stiffener surface
    Step 9: Finish
    Done
      • Pocket-Sized Contest
      • Spotless Contest
        Spotless Contest
      • Trash to Treasure
        Trash to Treasure
      3 Comments
      What is ARO? What is this rubber wall for?
      Sugru is the best! You should enter this in the First Time Authors Contest!
