iImage Information
Got an old Canon A1 laying around? Don't know how to use it? Well, if you fall into this category, then you may be able to take professional-looking photos with this rather than your digital point-and-shoot camera. You will be able to learn how to utilize this pro-range camera with just your point-and shoot skills. You will also learn how to diffuse/soften a flash, how to set the correct aperature, shutter and film speeds and also learn a little bit about multiple exposures with the A1. Also, if you are interested in panoramic photos, this Instructable will teach you all about it. I'm Eren S., and I will be your guide.
Step 1Learn the basic parts of the A1
iImage Information
The basic parts that you may need to use are listed in this step.
Step 2: ISO 800 film in bright daylight? I guess if you *have* to shoot at f/22 all the time (hello, diffraction) then that's fine; anything larger than than that and you're going to max out past the 1/1000 fastest shutter speed.
Step 3: You don't cock the lever halfway. In the picture (which is one I took; it'd be nice if you credited me for this and all) the wind-on lever is in the dead area of its travel. Pushing it to this position does exactly *nothing*. Also, it doesn't mention anything about advancing to the first frame. Just closing your back quickly (why?) and winding on once.
Step 4: Turning the dial to Av and setting the aperture, *then* turning it to Tv to set a shutter speed will do nothing to set the aperture manually, as you seem to be suggesting. Av lets you select an aperture and have a shutter speed set automatically, Tv allows you to select a shutter speed and have your aperture set manually. If you want a fully-manual exposure, you set it to Tv, choose a shutter speed, then set an aperture manually on the ring on the lens.
(I'll note that the title refers to the AE-1; the AE-1 operates quite differently, being a shutter-priority-only camera, and does not have an AT dial.)
>The faster, the less bright and the more grainy.
Film grain is a factor of the film you're using, not your shutter speed.
>The shutter speed I'd recommend for a well-lit room (no flash) is 1/400. At what ISO and aperture? If you're wide-open on an f/1.4 lens on ASA 1600 film, maybe, but you should say so.
>The aperture is how wide the shutter opens to expose the film.
No, it isn't.
>Now you know about aperture
You got this part right, but it's not from reading this. No discussion of the effects of the aperture on exposure?
>The exposure compensation is for low-light or high-light conditions.
No, it isn't; it's for conditions where you know better than the camera's meter.
"Canon A-1 Specialist"? Really?
