How to Use a Dishwasher
6,223
4
Published
Introduction: How to Use a Dishwasher
While many homes come with a dishwasher, you may have just moved into a place for the first time that has one. or Mom has taken off the training wheels and you need to learn to clean but wanna fat forward it all It can be intimidating to figure out how to properly use a dishwasher, but it will be a real time-saver.
Step 1: Observe the Dishwasher
This is important dish washers vary
Step 2: Open the Dishwasher
so you can know the parts
Step 3: Observe the Soap Space to Know Soap Needed
DISHWASHER SOAP ONLY
Step 4: Make Sure There Are No Dishes in the Dishwasher
Step 5: Open Bottom Rack
Step 6: Take Dirty Plate
prepare the plate for washing make sure its dishwasher safe
Step 7: Rinse Dirty Plate
Scrape off any excess food from the dishes before placing them in the dishwasher. If the food has hardened, you may need to let the dish soak first.
Step 8: Place Dirty Plate Between Racks
Place pots, pans, and bakeware around the other dishes, but do not block the water sprayer.
Step 9: Get Soap and Put It in Soap Space
Make sure its dishwashing soap The reason they tell you never to use liquid dish soap in your dishwasher is because of the suds - you'll have bubbles all over your floor. But the baking soda apparently prevents that, so it allows the soap to do the grease cutting and cleaning, without making all those bubbles
Step 10: Close Soap Space
make sure its secure
Step 11: Close the Dishwasher
Step 12: Know the Dish Washer Buttons and Cycles
Dish washers typically only have rinse only,light wash,normal wash, and heavy wash click normal then you should see a green light and or hear a noise indicating your choice
Step 13: Select Drying Type
Dishwashers really only have heated dry,Hot wash, or hot starts choose heated dry that is normal a green light and or noise will appear
Step 14: Leave the Dishwasher to Do Its Job
do not check on the dishes you'll interrupt in cycle depending on you dishwasher it may take up to atleast an hour to wash and dry
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    2 Discussions
    What's a dishwasher? I just put the dirty dishes on the counter and they end up clean in the appropriate cabinets.
