How to Use a L293D Chip With Arduino and a Motor
2,290
40
Posted
Introduction: How to Use a L293D Chip With Arduino and a Motor
Lets control an DC Motor with a L293D Chip and Make it so it will go clockwise or counter clockwise.
I received a kit from GearBest that included all the parts I needed for this project and recommend it to you if you are just starting with Arduino, You can check it out here!
The parts you will need are:
1) Arduino Board with PWM
2) L293D Motor Driver
3) Wires
4) External Power Supply (not needed but recommended)
5) 10 minutes
Lets Begin!
Step 1: Wire Everything!
Now were going to wire everything.
I created the schematic to make it easier to understand, then used that for reference when wiring it. Its super simple!
For people that cant see the picture notes:
In the schematic the bottom wire from the chip is the one you would connect to the power supply positive, i didn't add it to keep things simple.
Step 2: Code the Arduino
The code is super simple, we use "for" statements and "analogWrite" to control it.
For Example:
when pin 5 is low and pin 6 is high it will rotate clockwise
or
when pin 5 is high and pin 6 is low it will rotate counter-clockwise
You can download the code from here
Here is the code also:
void setup() {
void loop() {
  for(int i = 0; i<255; i++){
    analogWrite(5, i);
    analogWrite(6, 0);
    delay(5);
    analogWrite(5, 255-i);
    analogWrite(6, 0);
    delay(5);
    analogWrite(5, 0);
    analogWrite(6, i);
    delay(5);
    analogWrite(5, 0);
    analogWrite(6, 255-i);
    delay(5);
Step 3: Test It Out!
Your motor should now get increasingly faster then decelerate reverse direction and repeat!
If you have any questions leave them in the comments and i will try to help you out.
Hope you enjoyed
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
3 Comments
that speaker stabilizing solution is great!!
thanks, I actually accidentally had the motor attach to the speaker and thought "hey this is really useful". now I use it a lot
the rest if your instructable too :)
