Step 10Placing Materials
Once on, open the case, place your material where ever you plan to cut. This is where the rulers from the image come in handy, hopefully the laser cutter you're using has built in rulers to help you situate things. (If you're placing something in the upper left corner, and the bed is raised to high, do the following step first).
Once everything is placed (or before if you're feeling frisky), you may need to adjust the bed. If you look on the front control panel of the Laser Cutter, there should be a focus button. If you push that, and then the down arrow, you should see the bed lower. Keep lowering the bed until you have enough space that the laser will not come into contact with your materials. Extra space here is fine, we're going to let the machine focus itself later.
Every laser cutter I've used, won't print with the lid open, so it's a good way to do a test run on your piece.
Add Comment
