How to Use a Template to turn Multiples on a Wood Lathe
 by houndstoothy
Featured
This is a super simple way to create low fidelity multiples for prototyping purposes.
Step 1: Choose & Mark Material: Cut to Square
I chose some cheap construction grade pine for this exercise.  I'll be making 3 wheels for part of a chair mock-up.
Measure and cut squares; make a corner to corner 'X' to find the center on both sides.
Wroger-Wroger says: Jun 3, 2012. 12:17 AM
I'd center drill them all with a pilot hole, gang stack them and then turn them to a common OD, and then face cut them individually back through the stack..
ringai in reply to Wroger-WrogerNov 21, 2012. 12:01 PM
I don't think the blanks have a through hole. It looks like the headstock side has a steb center.
menskiy says: May 26, 2012. 9:45 AM
very interesting
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
