How to Use an HC-SR04 Ultrasonic Sensor With Arduino
Published
Introduction: How to Use an HC-SR04 Ultrasonic Sensor With Arduino
About: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths caused by my projects.
This instructable will show you how to use an HC-SR04 chip with Arduino. I got a kit from GearBest that has everything in it that you will need for this project, also this kit is very good for beginners and i would recommend you check it out here
You will need the fallowing parts to make this work:
1) Arduino Uno
2) HC-SR04
3) Wires
Let's Begin!
Step 1: Connect Everything Up
HC-SR04 | UNO
Vcc | 5v
Gnd | Gnd
Echo | 11
Trig | 12
That's it super easy, let's continue
Step 2: Program It
You will need the NewPing Library, you can Download it Here
I used the sample library sketch (i also included it below) and uploaded it to my Arduino UNO
#include <NewPing.h>
#define TRIGGER_PIN  12  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     11  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
void setup() {
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
void loop() {
  delay(50);                     // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
  Serial.println("cm");
Step 3: Test It Out
Open the Serial Port and test it out.
You now should be done! If you have any questions leave them in the comments and i will try to help you out.
Thanks for reading!
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
