Since each projector and monitor are different, prices and designs will differ. I will try to make the instructions as general as possible. I used an old Hitachi monitor and a Apollo Horizon Ultra overhead. I managed to get everything for free, and the same could apply to you! This project could take anywhere to a few hours to an afternoon depending on your specific situation and how much time you put into your fixture. The required skill varies from very little to experienced with electronics depending on if you can have the original power supply to the monitor and if the cooling fan needs to be soldered to a power supply.
Just keep in mind that the projector will be far from HD, but its a fun project and most people will find that the benefits outweigh the costs.
Remove these ads by
Signing UpStep 1: Gather Materials
- Overhead Projector
- LCD Monitor, as close to the size as the projector lighting surface
if the backlight is broken, that's fine. But everything else better work.
- Either the power supply to the monitor or two wires, better too long than too short. If no power supply, you'll need a power supply with the same specs.
- Fan (a small cooling fan, not a house fan)
- Soldering iron, solder
- Screwdrivers, both flat and Phillips head. You may need small screwdrivers depending on the monitor.
- Some wood, or any other material to construct a fixture for the electronics
- Saw. I used a "Saws-all", but any kind shoul do the job.
- Drill and drill bits. Screw sizes vary, but they will be small.
- Countersink (optional)
- A box of screws, possibly several kinds depending on the appropriate fixture
- Depending on how you secure the fan, you may need a router.
Not Nice
Visit Our Store »
Go Pro Today »
