Introduction: How to Wash Your Hands Properly (Or Teach Others Hand Washing) - Ebola 101
Picture of How to Wash Your Hands Properly (Or Teach Others Hand Washing) - Ebola 101
*On the surface Hand Washing seems simple, but doing it improperly can recontaminate your hands and leave you vulnerable to illness and disease.
Hand washing, as deemed by the CDC (Center for Disease Control and Prevention), is the single best way to avoid infection. Hand washing helps break up germs, dirt and other harmful particles on your hands with the combination of soap, water, friction and a paper towel.
On the surface hand washing is simple and elementary. However, many people do it improperly and actually walk away almost as contaminated (and sometimes more so) than before they washed. Plus, if hand washing is so simple then why don't all of us do it?
Follow the steps to proper hand washing to develop good hygiene and infection control habits. Once you have consistently incorporated infection control principles into your daily routines then you can experience increased health. Please note, we do not support over cleaning, hygiene OCD, germaphobia or other intense behaviors. We support a responsible approach to hygiene and recommend living in accordance with a few sound infection control principles.
If you have questions on how to best wash, teach others or promote hand hygiene then please email us (info@OUTFOXprevention.com) or go to our site www.OUTFOXprevention.com.
Enjoy!
Step 1: Prepare Towel Before Washing Hands
Picture of Prepare Towel Before Washing Hands
If available, prepare a paper towel before you wash your hands.  Most hand towel dispensers are automatic so wave your hand to have some of the paper extracted.  Do not remove the paper from the dispenser at this time.
Step 2: Turn Water on and Wet Your Hands
Picture of Turn Water on and Wet Your Hands
Turn the faucet on or wave your hand over the sensor if it is automatic.  If temperature control is available, get the water to a very warm level.  Caution, do not turn it too hot in order to avoid burning and to avoid eventual dry/cracking skin.  A comfortable level is adequate.
Step 3: Apply Soap Liberally
Picture of Apply Soap Liberally
Apply the soap available in the restroom or use the soap you use for traveling and emergency situations.  Lather the soap so that you can effectively cover the palms and backs of your hands.  Carrying soap with you can come in handy.  See your local store for sheet soap which is as thin as paper and intended for single use.
Step 4: Rub Hands Together and Create Friction
Picture of Rub Hands Together and Create Friction
Once the soap is applied, rub your hands together.  Rub every part of your hands on your palms and the backs of the hands.  Friction causes the germs and other harmful particles to leave the surface of your skin.  Since soap generally (most soaps anyway) don't KILL germs, you need to work hard to get all the germs off your hands through friction.
The general rule is to rub your hands for 10-20 seconds.  The spots that are often missed during hand washing include (but not limited to): The areas between fingers, the fingernail areas and wrist/thumb area.  If you want to teach a hand washing lesson with Glo Germ (fluorescent powder or gel that can show where people miss while washing if used under a UV black light) see: http://www.outfoxprevention.com/home/handwashing-kits-with-glo-germ/hand-washing-training-kits-for-infection-control
Step 5: Rinse Hands Off
Picture of Rinse Hands Off
After rubbing the soap all around and creating friction, hold you hands under the running water.  Rub the soap off and hit all areas of your hands once more as the water washes the suds and germs off.  Be careful not to touch the sides of the sink now that your hands are clean.  Once the soap has been washed off, leave water running.
Step 6: Dry Hands With the Prepared Paper Towel
Picture of Dry Hands With the Prepared Paper Towel
After rinsing your hands (without turning the faucet off), grab the prepared paper towel from the dispenser.  Dry your hands and slightly rub the towel over them to get off any remaining germs.
Step 7: Turn Faucet Off
Picture of Turn Faucet Off
After drying, use the paper towel to turn the faucet off.  Using a paper towel allows your hands to not be recontaminated.
If you think about the procession of hand washing, people touch and turn the faucet on when their hands ARE DIRTY.  If you are to touch the faucet once again after washing, you would be getting the same germs on your hands.
Step 8: Leaving the Restroom
Picture of Leaving the Restroom
With the paper towel still in hand from turning off the faucet, turn to leave the restroom.  If needed or possible, use the paper towel to open the door of the restroom.  This ensures that you are not getting germs from those that used the restroom but did not washing their hands properly (or at all for the matter).  Touching a bathroom door can contaminate your hands with the germs of others' feces... who wants that!
Step 9: Dispose of the Paper Towel and Leave Clean!
Picture of Dispose of the Paper Towel and Leave Clean!
Throw the paper towel away as soon as possible so that the germs are not spread to you.  This may seem like an intense process for hand washing, but it is quite simple when you get in the habit.  All parts of the process are intuitive but many times we are in a rush.  If you dedicate yourself to following the steps over a few weeks then it will be less cumbersome.  Good luck and we hope you can OUTFOX infection to avoid illness and disease!
OUTFOX Prevention
(910) OUTFOX-1 [910.688.3691]
Step 10:
Picture of
We have compiled these hand washing steps into a one-page guide that you can print and pass along. Simply click the this link: Hand Washing Instructions or paste the following link into your browser (the PDF download button will be at the bottom of the page on OUTFOX's site). The sheet is free-use so please feel free to print as many copies or pass the PDF to colleagues, etc.!
http://www.outfoxprevention.com/home/events-and-charity-causes/hygieneblog/howtowashyourhandsproperlystepbystep
OUTFOX also provides many other infection control activities, games and other hygiene tools to teach your students and employees. We distribute Glo Germ which is a great tool to teach hand washing and cleaning.
Let us know if you have questions!
brenna1123435 (author)2013-09-17
Cool. You should wash your hands properly
susanchen2011 (author)2012-07-07
Washing hands properly is very important.
shazni (author)2012-04-15
This is very good before eating and such.
else...well...what happens when you leave the wash room? do you use another tissue to open another door? or do you wear gloves? That would make us another Mr Monk ( the TV program) :-)
OUTFOX (author)shazni2012-04-16
You make an excellent point! We don't support an OCD approach to hygiene. For, there will be some things that we do that will allow germs in.... We just need to find out which habits will protect us the best without being over-the-top.
lemonie (author)2012-04-09
You're supposed to take rings off.
L
mrhodes4 (author)lemonie2012-04-12
U are so right that rings are great big collectors of germy material. Actually if you leave ur rings on they will be clean too IF U DO IT RIGHT (key words!). U don't want to have clean hands and put those germy rings back on.
So push ur rings up on ur fingers and wash the area under the rings well. Then turn ur attention too the rings. Turn them around on your fingers being sure to get soap all over them.
Of course u want to be VERY CAREFUL so ur rings don't slip off ur fingers and go down the drain with the germs (Which is what u are doing - the antimicrobal agents in OTC hand soap really aren't necessary. U wash MOST of the germs away and down the drain. Of course health care professionals need hospital grade antimicrobals that leave a residue on the hands keeping the number of germs there low.)
lemonie (author)mrhodes42012-04-14
Use "you" & "your" if you want people to think that your older than ~11.
L
mrhodes4 (author)lemonie2012-04-14
Thank YOU for YOUR kind comments!
OUTFOX (author)lemonie2012-04-09
Great addition! We will add that in. Thanks!
mrhodes4 (author)2012-04-12
One last tip and then I'll go! WET ur hands first. This is supposed to decrease the surface tension on the hands letting u lather the soap up easier.
This is a great lesson and something that really, really needs to be taught!
OUTFOX (author)mrhodes42012-04-12
Great information shared about wetting your hands! Thanks
I have to vote for this. I was an Infection Control Cordinator before I had to take a medical retirement. So I'd be out of the Bug Lady Club if I neglected to vote for this!
If you are a teacher looking for lesson plans, coloring sheets, songs, books, etc. I can give you a great low cost resource. I'm not sure if we are supposed to give out company info here or not.
Glad to see you are still in the club :)
Peytonomore (author)2012-04-10
That hand face scares me...
OUTFOX (author)Peytonomore2012-04-10
Not as much as germs should ;)
MindSplatDesign (author)2012-04-09
Nice work. Also in a recent lab experiment at uni we learned the length of time you have the soap on is more important than how much you rub your hands together.
OUTFOX (author)MindSplatDesign2012-04-09
I appreciate the information and hope it can help my readers! Thanks! OUTFOX
About This Instructable
13,825views
16favorites
License:
Bio: We focus on infection control and hygiene information. We distribute Glo Germ, Glitterbug and other fluorescent materials. We also distribute black lights, infection control posters ... More »
More by OUTFOX:How to apply solid lotionHow to Make Homemade Cleaning Wipes with HolderHow to Best Clean Your Phone, Tablet or Other Electronic Device
Add instructable to:
