I really enjoy water cooling and it recently became one of my new hobbies. A water cooling rig requires maintenance. You need to know your way around a computer pretty well to be able to do this. I've been building computer since I was 10 and this really pushes you to the limit. I want to go even farther and try vapor phase change cooling. It's pretty much building a refrigerator inside of your computer. Drops things to around -20C
The image shows my build before I cleaned up the wiring.
Some more pics of my computer here
Remove these ads by
Signing UpStep 1Finding your way around.
While white light does contain the full spectrum of light, the amount of UV rays emitted is very little. There is much more UV emitted from sterilization lamps than from lightbulbs.
Referring to a comment earlier, white light only helps plants and other photosynthetic organisms to grow. humans grow the fastest in the womb, not much light in there.
And finally, what many are/may be seeing in the tubes is algae. Algae DOES need light as it's a photosynthetic organism. Black tubing will stop light and therefore algae can't grow.
increaced
NO! THE KING OF GPU 0S GTX 295 YAAAAAAHHHH i got 1 and it didn't fit the pc case so i got a new pc case!
so ha
P.S. -My Nvidia GTS 450 can run Crysis at max detail, no lag easily. And thats only a 100$ card, so I'm not sure what the point of getting a card much better than a low 500s series is.
