I really enjoy water cooling and it recently became one of my new hobbies. A water cooling rig requires maintenance. You need to know your way around a computer pretty well to be able to do this. I've been building computer since I was 10 and this really pushes you to the limit. I want to go even farther and try vapor phase change cooling. It's pretty much building a refrigerator inside of your computer. Drops things to around -20C
The image shows my build before I cleaned up the wiring.
Some more pics of my computer here
Step 2: Picking out the parts.
You will also need about 10-15 gallons of distilled water. You can pick this up at your local grocery store. You also need tubing. You need to buy the right size tubing according to the type of pump, radiator, waterblock, and reservoir have. They are called barbs. I prefer 1/2 barbs. Make sure all your barbs are the same size. I recommend you use Tygon tubing. You can also use deionized water. I finally figured out the differences, I was pretty confused. Deionized water is less pure then distilled and still has some minerals and things like that in it. Both are still a bit conductive.
You also need some thermal paste. It helps create a strong bond between the CPU and water block so the heat can transfer. You can get a tube of it for about $5
Some places to buy watercooling parts
Petra's Tech Shop (My favorite)
Danger Den
Frozen Cpu
Newegg
Step 3: Preparing to install.
Step 4: Installing
Take the motherboard out of your case and put it in a safe place to work on it where static won't get to it. Put a dot sized dab of the thermal paste I mentioned before only a dot or 2. Get your screws that came with the waterblock and stick them up through the bottom of where your heatsink would screw in. Put the heatsink on and secure it.
It is hard to explain since all blocks mount a bit different. Your block should come with some kind of diagram. Think through where you are going to be installing you radiator and water pump. You might have to drill some holes into your case if you are mounting your radiator outside of your case. Once you found the places mount and screw them into place. Put your computer back together with only the essentials as you won't be needing to be able to boot just turn it on.
Plan out how you are going to do the tubing and connect them all on the valves. Get some hoseclamps and tightly secure them on. You might need to use kind of lubricant to get them to slide on. Make sure have things how you want them because it is extremely hard to get the hoses back off.
Step 5: Leak testing.
Another thing of I just thought of for leak testing is that if your pump doesn't use your PSU for power and the wall you can just plug that in. Another thing you can do is get an extra PSU and just hook the pump up to that. Then you can jump start it. Find a green and black wire on the Motherboard power connector and get a paper clip and bridge the connections. Make sure your PSU isn't plugged in when you do this.
Step 6: Putting everthing back in.
Hope this guide helped you and got you into the fun hobby of watercooling!
If you have any problems with building or watercooling feel free to contact me through instructables, IM, or email. Just don't bug me with virus and software questions. If you see something I missed please do tell me I made this thing at 3 am.
Xfire: CowGuy
AIM: Getacow123
MSN: ericrihm@hotmail.com
Email: cowsownyou@gmail.com
Also a great community to participate in is Xtremesystems. They are very helpful and just a great group of people.
Step 7: Additives
A few I recommend are:
PT nuke - It kills all kinds of bacteria and helps keep your loop from becoming dirty as fast.
Anti Freeze - There seems to be a big debate about this going on in the comment section. I use it and it does seem to help. I mix it in a 1:9 ratio to your water.
Liquid Coolants- There are a whole bunch of these, these are most of the time full water replacements. I have not had any experience with these, but I have mostly heard good things about them. Frozen Cpu stocks a whole bunch of different kinds.
Things to STAY away from:
UV dyes - Not all are bad, but some after a while will soon break down and become thick and murky and can damage pumps and reduce water flow. Make sure to look around and see if any of the reviewers of the product have been using it for a couple months before you buy it.
Step 8: Some Extra tips.
Get all the bubbles out of your reservoir. It increasing water flow.
Check your water frequently, It might start to grow some things in it or get some dirt in it if you didn't get all the crap out of it when you flushed out the parts.
Put some anti freeze in your water. Put a little in it helps with the heat transfer.
Never use Aluminum and copper or any other different kind of material on the water blocks. It can cause bad reactions. There are some chemicals you can add to protect them but I still don't recommend it.
Keep some extra tubing and distilled water around. If you don't have you reservoir sealed right or just from time the water will evaporate.
If you use black tubing it keeps things from growing in your loop.
KEEP EVERYTHING. Keep all the extra screws you have an old parts. Stuff like that. I don't know how many times all my old stuff I kept has helped me out.
Visit Our Store »
Go Pro Today »
While white light does contain the full spectrum of light, the amount of UV rays emitted is very little. There is much more UV emitted from sterilization lamps than from lightbulbs.
Referring to a comment earlier, white light only helps plants and other photosynthetic organisms to grow. humans grow the fastest in the womb, not much light in there.
And finally, what many are/may be seeing in the tubes is algae. Algae DOES need light as it's a photosynthetic organism. Black tubing will stop light and therefore algae can't grow.
increaced
NO! THE KING OF GPU İS GTX 295 YAAAAAAHHHH i got 1 and it didn't fit the pc case so i got a new pc case!
so ha
P.S. -My Nvidia GTS 450 can run Crysis at max detail, no lag easily. And thats only a 100$ card, so I'm not sure what the point of getting a card much better than a low 500s series is.
