**This Instructable is not intended to be THE definitive guide on MIG welding, for that you might want to seek out a a more comprehensive guide from a professional. Think of this Instructable as a guide to get you started MIG welding. Welding is a skill that needs to be developed over time, with a piece of metal in front of you and with a welding gun/torch in your hands.**
If you are interested in TIG welding, check out: How to Weld (TIG).
Remove these ads by
Signing UpStep 1Background
The heat produced by the short circuit, along with a non-reactive (hence inert) gas locally melts the metal and allows them to mix together. Once the heat is removed, the metal begins to cool and solidify, and forms a new piece of fused metal.
A few years ago the full name - Metal Inert Gas (MIG) welding was changed to Gas Metal Arc Welding (GMAW) but if you call it that most people won't know what the heck your talking about - the name MIG welding has certainly stuck.
MIG welding is useful because you can use it to weld many different types of metals: carbon steel, stainless steel, aluminum, magnesium, copper, nickel, silicon bronze and other alloys.
Here are some advantages to MIG welding:
- The ability to join a wide range of metals and thicknesses
- All-position welding capability
- A good weld bead
- A minimum of weld splatter
- Easy to learn
- MIG welding can only be used on thin to medium thick metals
- The use of an inert gas makes this type of welding less portable than arc welding which requires no external source of shielding gas
- Produces a somewhat sloppier and less controlled weld as compared to TIG (Tungsten Inert Gas Welding)
stainless steel manufacturers
Work safe, use the guards that the tools come with. If they weren't necessary the manufacturer wouldn't have put them on.
If it's in the way take it off, but replace it when that part of the job is done.
Grinders are made to remove hard metal by abrasion. Imagine how well they will work on soft flesh!
i only bring this up because i just finished taking a formal MIG welding class, and another student tried handing me a grinder, abrasive disc first, while it was still spinning,
after telling him to stop the wheel and to never do that again, he tried to tell me that i was ok, because i was wearing leather gloves and a leather sleeve over my welding jacket,
bottom line: pay attention and be safe, and as toyotero said use your brain, especially when others dont
I must say that I believe that every "intro to welding" written should cover more safety that was included in this one.
For example, readers should know that using a grinder without a guard involves some risk. I've done it to get into an area where the guard hindered me, but I was very careful when I did it and I replaced the guard immediately afterward.
Guards are your awkward friend that can save you from serious injury.
Most angle grinder injuries come from people getting metal particles in their eyes because they didn't wear proper safety gear. On occasion, the grinding/cutting wheel can snag and kick up or back toward your body... or more explosively the wheel can break while spinning 10,000 RPM and send pieces fly with substantial inertia similar to a grenade's shrapnel. The grinding wheel or it's pieces can go through thick clothing. The grinder guards can stop these particles and pieces from flying at your body or prevent contact between the wheel and your body, but not if the guard is sitting on the shelf.
Here are a few documented grinder injuries on a medical website.
http://www.head-face-med.com/content/4/1/1
One other hazard that must be mentioned in regards to welding are due to the materials involved such as metals, metal coatings and solutions that might be used to clean the metal to prep for welding. Everyone who owns a welder should familiarize themselves with these dangers.
For example, common brake cleaner might be used to clean oil or grease off of metal before welding. But if a drop is left on the metal, welding near it will turn it into phosgene gas which is a gas that was used to kill soldiers in WWI trenches.
http://www.brewracingframes.com/id75.htm
http://www.osha.gov/doc/outreachtraining/htmlfiles/weldhlth.html
I don't mean to try to scare anyone with these stories, I just want all my instructables associates to be aware of how to do it safely by identifying the dangers. Welding can be done with complete safety and is a very fun and rewarding hobby if proper precautions are taken.
Have fun and be safe. Use your tool guards, use sufficient ventilation and always use your brain. It is the most powerful tool we have to create new things and to keep ourselves safe.
Toyotero.
Don't you have anything to do.
Breath some of that gas....breath deeply.
The rest of you, use standard safety procedures, You'll be OK.
Have welded for a long time, in big sheds, in the middle of nowhere, under water....etc etc,
This is a good course, read it and "Ask lots of questions",
I don't think the bloke who's running it will care, Lots of fresh content gives you good google ratings...enjoy..:-)
Louis
Taizhou Genteck Electric Co.,Ltd.
Add:Eco.&Ind.Development Zone,Wenling,Zhejiang,China.
Office Phone:+86-576-86088668
Fax Number:+86-576-86088558
Email:louis@genteck.cn
Online service: MSN: genteckseller1@hotmail.com
Website:www.sparkwelding.com,http://genteck.en.alibaba.com/
They don't even have the proper data for their equipment on the website, all they are are cheap Chinese Knock-offs of ESAB equipment.
I purchaced an 120 amp welder from Harbor freight as I am not going to use this machine to do structural welding I got their middle one. ( there is one cheaper and one more expensive) I guess since I was buying crap I didnt want cheap crap. Any way they said that there is no need to use an external source of inert gas even though the machine is set up for it, I was told that I could use wire that has flux or some material that produced inert Gas while you are welding. Is that an inferior way to weld?and do I need to get this bottle?
The reason I asked this is because I have read almost through this whole article and the writer has only mentioned the flux core wire once. I got this thing because it was less expensive than a buzz box and I can weld thin metals easier but if I have to shell out more spondulix for gas bottles and gauges the price can go up dramaticly.
Michael.
flux cored wires require longer electrode stick outs and faster travel speeds. Also, you'll need to use a slight drag angle instead of pushing.
Rob
also switching to U-groove drive rollers will help feed aluminim wire more effectively.
the only problem is oxidation. after the weld you must grind and protect against rust.
When you set up a GMAW there are two settings, Wire feed rate, and Voltage (voltage is not the same thing as power)
overpenatration is a result of either incorrect settings, or incorrect travel speed.
Stringer beads are always preferable over a weave, weaving can cas porosity and incomplete fusion
lack of penetration does not always mean your settings where incorrect, it could also be a result of poor technique or of inadequate root opening.
from touching the table or any part of the pieces to be welded together no shock will occur just do not touch the bare welding wire and the tip with bare hands as you will feel some current and the same as when putting new wire in the machine don't touch the machine and any bare metal wire part when loading a new roll
especially around the roller feed as you will feel current again. I have been bitten a few times it is not at all very uncomfortable but it is still a little shock that surprises you and always do wear welding gloves not some cheap leather gloves real welding gloves they are thicker leather and have a longer cuff that protects your arms and wrist from getting flash burns from the arc and if you mess up and touch the hot welded metal been on the receiveing line a time or 2 not thinking and just reaching will get you a good burn and do always use the welding mask no blind welds save your eyes from sparks and arc flashes is a must there are a ton of other things but you will learn as you go
weld on dudes happy happy joy joy
http://www.harborfreight.com/cpi/ctaf/manuals.taf?f=form&ItemID=98871
You can get anti-splatter spray at a welding supply house. I have some, never use it.
If you are old enough to respect dangerous equipment, and have have reasonable eyesight and fine motor skills, you are old enough to learn to weld. That means almost every well-behaved and responsible 13-year-old is ready.
Best wishes in finding a teacher!
I am taking shop class right now
