3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Weld - MIG Welding
Step 6Welding Metal Together
Once you've got your method tested out a bit on some scrap, it's time to do the actual weld. In this photo I am doing just a simple butt weld on some square stock. We've already ground down the edges of the surfaces that are going to be welded so that the seem where they meet makes a small "v".
We are basically just taking the welder and making our sewing motion across the top of the seem. It's ideal to weld from the bottom of the stock up to the top, pushing the weld forward with the tip of the gun, however that isn't always comfortable or a good way to start learning. In the beginning it's perfectly fine to weld in whatever direction/position that is comfortable and that works for you.
Once we finished welding the pipe we were left with a big bump where the filler came in. You can leave that if you like, or you can grind it flat depending on what you are using the metal for. Once we ground it down we found once side where the weld didn't penetrate properly. (See photo 3.) That means that we need to have more power and more wire to fill in the weld. We went back and redid the weld so that it was properly joined.
1 comment
Apr 22, 2010. 8:04 PMobrie021 says:
 Learn early the importance of "tacking" pieces together. Failure to do so will often draw pieces apart or otherwise deform the joint. Consider clamping the pieces securely or apply a tacking bead on opposite sides before throwing the heat to it. A lesson I learned the hard way building my first go cart many years ago.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
891
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
