Step 9Wire Fuses to Tip/Change the Tip
If you really scorch the tip of your gun and fuse the hole closed with metal then you need to turn the welder off and replace the tip. Follow the steps and the overly detailed photo series below to see how it's done. (It's digital so I tend to take too many pictures).
1. (Photo 3) - The tip is fused closed.
2. (Photo 4) - Unscrew the welding shield cup.
3. (Photo 5) - Unscrew the bad welding tip.
4. (Photo 6) - Slide a new tip into place.
5. (Photo 7) - Screw the new tip on.
6. (Photo 8) - Replace the welding cup.
7. (Photo 9) - It's now good as new.
I purchaced an 120 amp welder from Harbor freight as I am not going to use this machine to do structural welding I got their middle one. ( there is one cheaper and one more expensive) I guess since I was buying crap I didnt want cheap crap. Any way they said that there is no need to use an external source of inert gas even though the machine is set up for it, I was told that I could use wire that has flux or some material that produced inert Gas while you are welding. Is that an inferior way to weld?and do I need to get this bottle?
The reason I asked this is because I have read almost through this whole article and the writer has only mentioned the flux core wire once. I got this thing because it was less expensive than a buzz box and I can weld thin metals easier but if I have to shell out more spondulix for gas bottles and gauges the price can go up dramaticly.
Michael.
flux cored wires require longer electrode stick outs and faster travel speeds. Also, you'll need to use a slight drag angle instead of pushing.
Rob
also switching to U-groove drive rollers will help feed aluminim wire more effectively.
