Step 2Grind the Electrode
Do this, especially if the rod is a brand-new cylinder and doesn't have a pointed or rounded tip yet.
The tip will become rounded due to heat as you weld.
Lincoln recommends a balled tip for AC welding, and a pointed tip for DC welding.
The pointed tip will give a smaller, more directed arc. The arc will tend to dance around, when from a rounded tip.
now, I am always a little scared of the tip catching on the wheel, and the rod flying out of my hands, but that hasnt happened yet. thank god.
point the rod up, towards the rotating wheel coming towards you.
that way, the rod is ground in the right direction ... something to do with current flow ;)
Always point the tungsten up. You can also hold the tungsten horizontal to the wheel to speed up grinding, but you MUST finish in the vertical position. Like you said, horizontal lines on a tungsten with play with the current flow.
