Step 6Prepare Metal and Welding Table
Beauty Tip: Use a wire brush to scrub the surfaces of the metal. It's good practice to keep a dedicated aluminum brush (separate from what you use to clean steel). If you want really nice-looking welds, you can also wipe down the welding rods with acetone.
If you don't care about the way the welds look when finished, don't bother and you'll be fine. However, your welds will be a little weaker and not as pretty.
Clamp your metals so they'll stay where you want them when you weld.
And, if you have the stuff, spray down your welding table with anti-spatter (so if any metal leaks off, it doesn't stick where it lands, which is important if you're trying to keep your surface flat).
comments
Add Comment
stasterisk (author)
says:
Add Comment
