Step 3Mounting the Wall Plates
Now that you've decided where to mount the box, you need to draw the lines on the wall to fit the new box and cut the hold with the pointed hand saw. The pointed saw should be able to push through the dry wall pretty easily without the need to drill starter holes.
Once you have the hole cut in the wall, you can put the single gang box into the hole and screw the clamps with hold it in place by clamping to the back of the dry wall.
Repeat this for each location that you want to run to.
For now we'll leave the wall plates off.
At this time you'll also want to cut a hole in the wall in the distribution room. Here you want to cut a hole that the plastic grommet will fit into.
Now we can run cables!
![D-Link Wireless Router DIR-628 Setup [Without CD]](http://img.instructables.com/files/deriv/FDQ/ZBHK/GIYWWBMF/FDQZBHKGIYWWBMF.SQUARE.jpg)
They are commonly used for pro-audio.
He kinda went overkill on the amount of rack space...
The exception was in the entertainment room - My parents already had two speaker wires coming up from the floor to the stereo system. These were moved six inches so they came up through the wall where the coax came up from the basement, and went to RCA jacks in the 3rd and 4th holes in that wallplate.
It's a MUCH easier approach than adding wallplates if you're doing the "Cat5 only to places with a coax drop already" approach!
For multi-drop Cat5/6 you'd need to get a 4 or 6-port wallplate (1 for the old coax, 2+ for the multiple Cat5/6 jacks, but they don't have 3/5 port plates.)
