Step 7Connecting to the Internet
First the cable modem setup. Since I moved my cable modem from my second bedroom (office) to the distribution room I needed to change the way my cable was split. Rather than the main cable into the house being split 3 ways I split things a little differently. I split the incoming cable with a 3-way splitter first. 1 to the main TV, 1 to the 2-way splitter for TV in the bedrooms and the other into the cable modem. I connected the splitters using a male-male barrel connector.
Now that the cable modem is in the right place we can continue with our network setup. Depending on your internet provider some of this setup may vary. I'm going to discuss the specifics of my environment only. I'll provide tips for others when possible.
From the cable modem ethernet port I plugged into the "Untrusted" port on my router/firewall. From the "Trusted" port, I connected to the first switch port on my switch. If your switch has one, plug into the port labeled "Uplink" instead. Depending on the switch or cable modem and or router, you may need (or already have) crossover cables for these connections. With my router/firewall set up as a DHCP server I can now provide each port access to the internet. In addition my entire network is protected from outside access by the firewall.
Although it is not integral to this instructable, I also plugged a wireless access point into my switch so that I can have wireless access as well. Since my wireless is both encrypted and has MAC filtering I feel comfortable with it on the "trusted" side of my firewall. If for some reason I wanted to provide open wireless access but still protect my network I would need a different configuration of connections. I won't go into detail about these changes but I wanted to note them depending on what your network goals are and how they might incorporate wireless access.
In summary, my firewall receives my single, static IP from my ISP cable modem. It also acts as a router and provides DHCP IP addresses to all other hosts on my private network via the switch and cabling we just installed.
What the hell do we do with it now?!? NEXT!
![D-Link Wireless Router DIR-628 Setup [Without CD]](http://img.instructables.com/files/deriv/FDQ/ZBHK/GIYWWBMF/FDQZBHKGIYWWBMF.SQUARE.jpg)
Also, you can use a Linux router and you can incorporate many of your solutions in it including the routing function, RADIUS, firewall, access list policies and you can go way beyond that!!! Also, if you don't have multiple networks that you have to trunk that is quite uncommon in a home environment setup, you don't even need CISCO. There are plenty of switches out there cheaper that know Gigabit technology and also know 802.11q, STP and more at a fraction of the CISCO cost.
As for the router, Linux knows how to handle 802.11q, so VLANs are not a problem and you can easily route RIP, OSPF and BGP, but again, I don't see the point at home...
These are just few of the improvements I would do, but besides that CAT5/6 is great for speed and security and it has it's very own purpose where it's installed.
And again, while you berate me for using Cisco because you think it is expensive and overkill (I got mine for free), you are the one using RADIUS in a home environment and talking about 802.1q. Talk about overkill. I guarantee no information you have is that important (regardless of how important you already think you are).
Oh, and a Linux router that you build, would be a downgrade from the netscreen. I'll take a commercial solution over a cobbled together solution anyday.
Thanks for a nice instructable.
However, the Internet was fine even if the speed was affected because 99% of the stuff out there is based on TCP, and it is corrected if the packets get dropped or corrupt, but VoIP is UDP and if the packet gets lost, it lost for ever, so that's the reason my phone was dying every time.
The solution was to move the coax line for the phone elsewhere in the house where I don't have CAT5, so the problem got solved. If you ever run CAT5/6 nearby coax, think of what I told you! It will save you a LOT of grief and time!
And getting back to the CAT5 idea. This is NOT bad, but you could install shielded cable because the technology changes fast and like that you could accommodate a better technology into the close future. So, I would recommend CAT7. Like that, you avoid interference and you can jump to the next technology.
Cheers!
Hmm. You might also note that the little connectors, like you have between the two, may be a bad idea too, assuming they work like cabling. Besides making the whole mess hard to shove back into the wall, anything less than 6 inches causes signal reflection, at least in cables, which mucks with the signal too. I would presume that those short connectors "may" do something similar, but I could be wrong. It may not hurt your TV much, but your cable box, if you have one, is basically a cable modem + TV tuner, and you might be adding additional noise there, which could muck with them working right as well.
