3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Wire a Turned Wooden Lamp
Step 5Add the Lamp Socket
Add the Lamp Socket
I can usually get my hands on some electrical cords (every first of the month somebody throws away a lamp on my block) and I get some good deals on wood. But I will always pay for top of the line lamp sockets. The best I've ever worked with are from Grand Brass (trust me they are the best]). The model I'm using here has a built in dimmer, and is so worth the money.
The lamp socket is composed of 4 parts: the ring, the bottom socket cap, the socket interior, and the socket shell. Place the ring over the wire and threaded nipple. Screw on the bottom base to the threaded nipple. Tighten the set screw when the base is secure.
Tie the ends of the wire into what is known as the underwriter's knot, this prevents it from being pulled back through the lamp.
Follow the manufacturer's instructions to find the hot and neutral wire (the neutral wire often has ribbing on it). Connect the neutral wire to the silver screw on the socket. Connect the hot wire to the gold screw. Tighten the terminal screws, making sure all of the wires are under the screw head.
Place the socket shell over the socket interior and tighten the ring.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:blightdesign
http://blightdesign.com/unfinished/ http://www.flickr.com/photos/95553564@N00/sets/
