How to Add a USB Fingerprint Scanner Internally to Laptop
32,330
37
8
Posted
Introduction: How to Add a USB Fingerprint Scanner Internally to Laptop
I had a Dell Mini-9 that i installed Mac OS X onto and in the process saw other users adding an internal GPS receiver. This got me thinking, could I add a fingerprint scanner into it. The users of http://www.mydellmini.com were instrumental in the initial setup as one of the user found out where and how to add internal usb solder points. With this information I decided I had enough to tackle the project.
For this project you will need to have good soldering skills as there are some small points to solder to.
Tools needed:
Soldering iron and solder
Jeweler's screwdrivers
small files
Dremel
Dell Mini-9 (or any laptop worthy of modifying)
USB Fingerprint scanner
USB hub which you will dismantle as well
Double sided .001" thick Kapton Tape
LOTS OF PATIENCE as you will be ding some small soldering and drilling and filing away plastic from the palm rest and this can not be undone once it has been started.
This is my mod, I orginally posted it to the my dell mini forums and thought it would be good to have it here for more people to see and get ideas for their own. This has been seen on many other sites, doing a search on google for "dell mini-9 fingerprint scanner" brings up on lots of tech pages.
If you are ready to tackle this fun project let begin!
Step 1: Disassembly of the USB Hub
First we need to take the USB hub completely apart so that the circuit board is exposed and you have some length of wire still attached to the circuit board.
Photo 1 shows the USB hub in its original case. (This photo is not mine as i was too anxious to get the project started)
Photo2: Remove the 6 screws holding the case together
Photo 3: Bottom cover comes off easily
Photo 4: Partially remove the top cover as to not rip off the wires from the circuit board, once it is apart far enough go ahead and cut the wires leaving enough that you know what color is what solder point
Photo 5: case is off the circuit board
Step 2: Lets Have a Look at the Circuit Board
Once you have the circuit board alone I went and made a drawing of each set of wires so I can later look an solder the wires up correctly to the fingerprint scanner. It is very important to make sure the wires are correct otherwise you risk frying the attached devise by wiring the positive to the negative or to one of the data points.
Once you have the layout of the wires I used the instructions here to wire the hub interantlly so it wont use one. I want to give a big thank you to the user that posted that as it was very helpful for this project, and future potential USB add-on's.
Once you have the hub installed we can continue on to the fingerprint modification.
Step 3: Disassembly of the Fingerprint Scanner
Lets take a look at the scanner I used. When I received this i was skeptical that it would not fit because of the size and weight of the device. I decided to dive in and see what it looked like inside, as that was the whole reason I bought the scanner and did everything to this point.
In the first four photos you can see the size of the device and why i was skeptical it would work. And on the fourth photo the weights they add so it would not slide when used.
As there are no screws holding the two parts together I used a small flat head screwdriver to pry the two pieces apart. I was not worried about snapping the plastic as it was no longer going to be used, but was cautious not to cause any damage to the internal card with the screwdriver.
Step 4: A Further Look at the Scanner
Now that we have the scanner apart, lets look at it more. As you can see, the actual circuit board is very small and thin, Perfect for installing inside the case.
DO NOT CUT THE WIRES YET, you will use these to solder to the USB hub installed earlier. I do suggest cutting the outside  sheath off as it is bulky and makes it difficult to run the cable around. I left mine on but would have removed it first if I were to do it over again.
The other card is my Runcore SSD for a size comparison
Step 5: Now for the Fun Part
This is where you will need lots of patience so you don't screw it up.
After disassembling the case per the MFG manuals I was looking where to place the scanner. I finally decided to place it under the right side palm rest as the only thing under it is the bluetooth receiver, and that is small enough to move.
The first photo shows the underside of the palm rest before grinding away the plastic posts. I did remove some foil in the area from the start because i knew it would cause problems with the circuit card if left there.
Using a Dremel with a cut-off wheel, SLOWLY grind away the posts until it is flat with the palm rest. To get through the inserts (metal bits for the screws) I ground a slot right thought the middle of the post so i can pull out the metal insert easily
Once you have ground it down it should look like the second photo
in the third photo I laid out the bluetooth and scanner to see a final fit before drilling through the case. As you can see it is a perfect fit between the bottom lip and the top lip, like it was meant to be there.
Once you have the location of the board it is very important to start slowly. Drill three small holes using a sharp drill bit and going slowly. I used the drill bit in my fingers to i would not risk breaking the plastic and could feel it if bound up so I knew to stop. The hardest part of this is making sure the holes are in the center of the scanner bar. Once you have the holes drilled it will look like the fourth photo.
Now take a small flat file and start making the rectangle shape to fit the scanner's pickup. This should take longer that 30 minutes as to not take off too much. I kept checking the fit of the scanner every few minutes
The last step is to add a bevel to the top of the palm rest so that your finger can dip down and make easier contact to the reader bar. When i did this the file came off a couple times and scratched the top. Something that can be done to help stop this is to add a piece of masking tape just at the edge of where you want the edge of the bevel to meet the top as seen in the last photo
There are a few things that can be done to hold the scanner in place.
I prefer to use doublestick tape so that it can be removed if needed but still has a great holding power:  This is the tape I used between the palm rest and the circuit board for its properties with electronics, its thin, and has good holding and heat properties. Click here for (.001" Kapton®/Polyimide w/ Silicone)
Hope you enjoy this Intractable. Please post your comments
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
11 Comments
gonna try something like this, but with a thinkpad. have a L520, and really want it to be unique, and a fingerprint scanner in the right place can do jut that, on most thinkpads, its under the keyboard, im gonna put it next to the keyboard.(using a different reader, and a few other changes)
This was very easy to do, just take your time, plan out the location of everything and it will come out looking good. Would love to see the final project.
Nice Instructable, but only 1 comment: Macs suck :P
Thank you.
As for Mac's to each is own. I had had that mini running Mac OS X with no issues, and the macbook I have had for 3 years and have not had to do a single reinstall, unlike my experience with windows where its every 6 months. But I look at it like this, some people love fords and hate Dodge, where others are just the opposite.
Eh you win some you lose some, just putting in my 2 cents :) (The only reason I think they suck is because Apple puts unnecessary things into Macs, so they can bump the price up. It would cost me <$1000 to build a PC with the same or better specs as a $2000 Mac. But as for the OS itself, I've never had any problems with my Windows :))
You are totally right about the pricing, yes they are up there, but defiantly worth it in my book. For adding extra stuff into it, not so much, unlike the windows OS. I think a lot of my issues with windows was the fact of installing things all the time and I like to try new stuff on them. I have talked to a few others that have had great luck with windows and for that I give you kudos.
Thanks for the comments guys!
That's the thing I don't get about OSs. My installation of XP has NEVER given me ANY issues, or bug reports, or any other BS. Then some other guy can have it crashing every 5 minutes :/
My nickel of a thought, I'm an MCSE who has both Win & OsX...I can tell you that the majority of the problems win users have is due to user errors (download something from the cloud, with spyware injected into registry) or hardware problems (Win doesn't like hardware prob's, No BUENO)....as for Mac's I don't buy them new, (saves a few pennies) the OS runs smooth with little headache....The same can not be said for win, the numerous updates one has to maintain is dizzying.... OsX being unix based code is a much stabler platform when compared to Win.... i could go on....but personally I prefer Linux(CHEVY GTO) which just does what its told.....
