3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to add more Outputs to your Microcontroller
This Instructable will show you step-by-step how to add 8 extra digital outputs, using only 3 of your microcontroller's digital outputs.
Step 1Which Microcontroller Should You Use?
In order to do this Instructable with your microcontroller, you will need to make sure that it has the following:
(3x)......Available Digital Outputs (Analog/PWM Outputs will work too)
(1x)......Ground/GND Pin
(1x)......10k (or more) of programming space
8 comments
Jul 3, 2011. 8:26 PMnjkl44 says:
lets say i wanted to add more analog for sensors, what would the code look like then?
Mar 17, 2012. 7:40 PMQtechknow says:
I think that instead of a pwm expander, (for analog output) you would need a mux(multiplier) to expand the number of analog inputs. Sparkfun has a $5 breakout
Mar 8, 2012. 3:19 PMFoxtrot70 says:
How do you force a chip to start on the last program running after a power down?
Jan 6, 2012. 10:31 AMsamj2 says:
mention the controller please?
Jul 14, 2011. 5:53 PMaxeman911 says:
will it work without the capacitor, if we just connect it directly to ground?
Jul 3, 2011. 8:21 AMphevtron says:
very straight forward :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:TECH GEEK
