I am a small developer of embedded soultions for all types of applications. One my personal interests is with GPS positioning products. To satisfy some previous patent work I was doing I needed a device that would record large amounts of gps data (lots of memory) over a long period of time (big battery) and was compatible with mac's and pc's. Unfortunately, nothing of this sort existed and I had to create a device to do this.
This product is the culmination of implementing a number of new designs for myself. Mainly, using surface mount components, lithium ion/polymer batteries, and Sandisk SD memory cards.
Since so many electronics parts are surface mount these days I needed to use these components but was a little bit fearful in making the leap from using through hole/traditional soldered parts. Sparkfun Electronics helped my learning with their tutorials and I thought I would continue the tradition through an Instructable.
Remove these ads by
Signing UpStep 1APPLY SOLDER PASTE WITH ACRYLIC STENCIL
Picture 2. Tape Top of acrylic stencil to board; make sure it is properly aligned over the pads of your pcb.
Picture 3. Using your preferred solder paste apply a good sized glob to a simple plastic paint spreader
Picture 4. Spread the solder past liberally over your acrylic stencil. Make sure to cover all the holes!
Picture 5. In the next 2-3 passes try and remove as much solder paste from the stencil as possible.
Picture 6. You should have almost the same amount of solder paste your "spatula" as you began with except for the holes in the stencil.
Picture 7. After carefully pulling up your stencil and removing the pcb you would repeat this process for the next board. When complete be sure to remove all solder paste from the stencil. I prefer windex and a toothbrush to clear out soem of the holes for really tight pitch components.
http://www.sparkfun.com/commerce/categories.php?cPath=4_86
The Global Positioning System (GPS) is a fully functional Global Navigation Satellite System. Satellites transmit signals that enables a GPS receiver to determine its location, speed and direction.
Surface mount technology (SMT) is a method for constructing electronic circuits in which the components are mounted directly onto the surface of printed circuit boards (PCBs). Electronic devices so made are called surface-mount devices or SMDs.
(definitions were from http://en.wikipedia.org/)
This device would gather GPS data and store it on the SD card so it could later be uploaded to a computer to determine where it (and also who/what its attached to) has been. There are many different uses for such a device, parents (or employers or the FBI) often use them to track where (and how fast) there child (or employee or suspect) has taken their car. Some people also just like to know where they have explored or how fast they biked or how far they ran.
