I have found that once you get used to it, sleeping on a hammock is much more comfortable than on the ground. Furthermore, you will never have to worry about a ground tarp, uneven, rocky or wet ground, and can probably eliminate your tent as well as some other gear.
Please note this is a guide for beginners, and does not cover more of the technical aspects of hamocking. If this guide has gotten you interested and you want more information on Hammocking I suggest you go to the Hammock Forums, where there is a ton of information on all things hammocks. I'm currently planning revisions for this instructable based on the methods that I learned from HF and now use myself, but for this guide should be adequate.
Remove these ads by
Signing UpStep 1Gather Materials
One hammock
parachute cord (
2 carabiners
one foam sleeping pad (yes, those cheap, foam sleeping pads you swore never to use again after you got your inflatable pad)
I will be providing to you:
a basic knowledge of knots
A note on hammocks: buy a good, light hammock. No heavy braided cotton line. the one i use is an Amazonas Traveler, made from parachute nylon and weighs 11 ounces and holds over 300 lbs. at the time it was around $20 at the local sporting goods store, look around and you should find one similar. There are also many options for making your own hammock, and plenty of commercial options.
A note on Carabiners and rope: use only load bearing carabiners, designed for climbing. These carabiners end up supporting much more than your weight depending on how tight you string your hammock. for this same reason, the golden standard for rope in the hammocking community is Dyneema, or Spectra, which are incredibly strong, low stretch materials. I now use 7/16" Dyneema that can hold something around 5000 pounds and is very lightweight. Paracord works, but Dyneema would be preferable.
Hammocks (hamacas) are used from the Yucatan peninsula to Venezuela, some people don´t even have beds!
look up the hamacasutra and you´ll see LOL
Make two "sheet" hammocks, place a separator on one end where the "heads" go and voila... just use good, strong rope and it can probably be done for under $20, minus the rain cover, but even that's not expensive with a tarp.
I just made a simple sheet hammock this past week with cheap rope and had three individuals in it at one time (not sleeping, just testing). The rope was only rated at 120 lbs... but it held.
I like the two man version though from the site; nice idea!
For the end attached to the tree, use a 'taught line hitch'. Wrap the rope around the tree at least twice and then tie a taught line about midway down your rope. Then you can adjust the rope and "lay" of your hammock without having to retie the knot.
