3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to bend tubing
How to bend tubing
Here, I show a quick and dirty method to bend aluminum tubing. I am documenting how I built a new bow rail for my sailboat.
Step 1Build the jig
Build the jig
Here, I trace the curve that I want on some scrap lumber. This scrap will be used to build the bending jig. I'm just using a couple of old 2x4's. Your wood should be somewhat thicker than the diameter of the tube you wish to bend.
65 comments
1-40 of 65next »
Apr 5, 2010. 11:34 AMEvox_Rider says:
I have been looking for alternatives to buying conduit benders (they are not cheap...and I am...lol).  Would doing a jig like this, but for a small 3 or 4 inch radius work for 1/2" conduit? or would it kink?
Oct 5, 2011. 7:12 AMGreyBird says:
I use a spring to bent PVC Conduit. For long pipes I attach a rope on the one end and shove it down the pvc until it is in place. My spring was inexpensive. Hope this helps.
Apr 5, 2010. 5:21 PMEvox_Rider says:
 I was thinking if it does kink, to try and make a groove in the edge of the half circle part to match the conduit (thinking to maybe mount the full circle into the drill press and use it as a makeshift lathe)
May 22, 2007. 7:28 AMPunkguyta says:
I bend metal with my hands.
Mar 10, 2008. 7:43 PMjongscx says:
yeah? well I do it with my mind...
Aug 5, 2010. 6:53 PMNinjaBear says:
So? ... I can do it without my mind
Jan 28, 2011. 3:02 AMgossumx says:
Well, it can bend itself without me.....
Mar 2, 2011. 7:19 AMjayeshshinai says:
its so easy, i make someone else do it for me..
Jun 3, 2011. 11:54 AMRWWESTdesignworks says:
you are all bending it the easy way, tubing was just flat strips of sheet metal before I started bending it into cylinders...
Jun 4, 2011. 10:21 AMjayeshshinai says:
it was so easy...ilet u do it ...(nothing personal^, just goes wid flow)
Apr 23, 2011. 6:43 PMMurdok says:
If you are super concerned with getting a smooth rail, fill the rail with sand and close both ends. When you bend the tube it won't kink or deform.
Feb 7, 2011. 4:53 PMrwhorton says:
I have had a little experience bending tubing, as I was a band director who "dabbled" in instrument making in my early years.
I successfully bent brass tubing using molten lead (which I reheated and removed later) inside the tubing. If you are not trying a real tight curve, then this should keep kinks from forming.
Another way I have seen, but never tried, is to freeze water in the tubes, and then bend them. (Saw this on T.V.) I imagine you could place your pipe into a freezer, as long as it will fit.
Feb 18, 2008. 8:13 PMdlfynrdr says:
I want to make a bicycle handlebar like the one shown in this pic. Would this be a good technique to do it with? Can anyone suggest what thickness of aluminum to use? Thanks, in advance
Apr 5, 2010. 3:58 PMcorrysoccer16 says:
One thing you might want to try to do is to fill it with something.  Brass instrument companies do this to prevent collapsing the tube.  They use a bees wax and tar mixture i am sure you can find a recipe online for it.  But at this point you may just want to do what another person posted which is just cut another pair of drop handle bars.
Jul 4, 2010. 4:20 PMsedague says:
I recently watched an episode of 'Factory Made' on the Science channel. They made the bends in a brass trombone by filling the brass tube with liquid and freezing it. The ice core kept the tube from collapsing. I don't know if this would work in this case since more force would be required to make the bend than is needed for the brass tube.
Apr 5, 2010. 3:37 PMFujitsa says:
Why not try something more different? like go for a shape that no one else has! and show off your coolness!
Jan 5, 2010. 9:21 PMkg6gfq says:
Probably easier to find a set of old drop bars and apply a hacksaw.  They won't look exactly like this, but bending tube to that shape, especially with this method, seems like it could be tricky.
Mar 23, 2008. 9:49 PMRishnai says:
It would definitely be a cost-effective way to do it, but beware about getting enough force to make the bends out by the grips. You'll have to bend with a longer tube and then cut to length for sure. Also, getting that compound bend (down and then real near to it, towards you), will require careful bracing when you build your jig. I learned that the hard way when I was bending conduit to run electricity to my swamp cooler and had to make some funky bends like that. I did the actual bending a different way, but I found I had to build a bracing jig all around the bend I had just made and then begin my next bend. It was the only way to keep the angle inact, and have a stable force to bend against. As for aluminum thickness, unless your old handlebars have collapsed in some way, use that thickness. Otherwise, I would use electrical conduit. It's cheap, handy, and relatively easy to bend. I wouldn't use it for apehangers or if I was going to put a lot of weight on my hands while I ride, but for that style, conduit should be fine.
Sep 22, 2009. 9:04 AMjcmaner says:
if you fill the conduit with sand it will not kink
Jul 28, 2009. 9:25 AMidostuff says:
Making some custom handlebars for my road bicycle... Would there be any advantage to using BOTH sand and water inside the tube?
Mar 28, 2008. 7:53 PMdrevt says:
Great instructable! I have two questions though: I am looking at making mtb bars, out of steel preferably, and I'm wondering if a) it would be possible to bend steel using this method, and b) would it be possible to make a jig that would allow the middle section of the handlebars straight for ease when fitting it onto the stem (sort of like these )?
May 28, 2007. 8:18 PMsti390 says:
What is the max size of pipe(diameter) I'm able to bend it over the jig?
Mar 23, 2008. 9:51 PMRishnai says:
Without heat? I guess that depends on how sturdy your jig mount is, how strong you are, and how thick the walls on your chosen tubing are. Of course, if you get some tubing home and find you can't bend it, heat with a propane torch (don't light your jig on fire) and then bend. Make sure you evenly heat everything that you want to have bent evenly, and the sky's really the limit.
Jul 4, 2006. 2:44 PMScott Dallesasse says:
How about just going and buying the right size conduit bender?
May 24, 2007. 9:08 PMPaulcet says:
Conduit benders are fixed-radius, but with the wood form it can be any radius you want, even varying radius.
Sep 22, 2006. 10:25 AMDiamondBack says:
a conduit bender bends pipe. While you can get aluminum pipe, this how-to talks about bending tubing. If you were to attempt to bend tubing in a pipe bender, you would end up putting a serious kink in the tubing - rendering it unattractive, and useless But, doing this rail WITH conduit, and the conduit bender, might be a viable alternative. Polish it up with 2-3 grades of emery cloth, and it could look quite attractive
Apr 9, 2007. 2:49 PMbethehammer says:
Add a torch and this is a good way to bend steel tubing/pipe also...
Mar 31, 2007. 10:41 AMsdallesasse says:
Great subject. From experience I can see that you are on the right path. You have almost everything component that is included in a commercial tubing / conduit bender. You have the shoe / form and the hook / scrap block. The only thing you need is a follow bar. Some sort of item to squeeze the tubing to the form / shoe to keep it from kinking. In hand benders this is accomplished by using the ground / floor. I think that if you wanted to use your jig that is pictured, all you need is a reinforced slot that would be parallel to the jig and justwide enough to allow the tubing to fit. Then you would need some sort of metal bar that you could pull along this slot to squeeze the tubing to the form.
Dec 8, 2006. 10:22 AMpojken says:
I've seen how trumpet guys do it - they fill it with water and then freeze it. Problem is, how would you freeze it unless it's winter outside. Any how, that's another alternative if you're looking for one.
Mar 10, 2007. 5:24 PMCabofixe says:
I just wanted to make a clarification on here. The trumpet guys don't use water because it freezes into ice and isn't bendable. Also pure water expands when it freezes and can crack or break tubing when it freezes. They use a soap/water mixture because it can still bend. And doesn't expand as much.
Jan 2, 2007. 4:57 AMhandymann says:
you can bend it just as effectively by packing the aluminum tubing with sand tightly packed into the inside of the tubing, then do the rest as the instructions say
Aug 6, 2007. 10:36 AMRibs says:
Why would you want to fill it with anything at all? wouldnt that just make it harder to bend?
Aug 13, 2007. 6:01 PMELF says:
Because when you bend it, the "outside" (blue line) of the curve has to be longer than the "inside" (green line). If you don't fill it, it will of natural reason deform in the profile (red circles) when you bend it... This may cause collapse, which is what I THINK is what they mean by kink. Illustration 1 is of a tube bent with something filling the inside of the tube, to force a constant volume, and thereby force the tube to stay in shape. illustration 2 is of the tube without filling. Notice the red profile cut half-way. Hope that helps :)
Aug 15, 2007. 5:47 AMRibs says:
Thanks a lot that makes more sence now. and it is kink i think.
Nov 23, 2006. 9:44 AMsuch_momjeans says:
The Ghost in our old house frightens the kids when they get up to pee in the middle of the night. I made lighted paths from their rooms to the bathroom that they can turn on from bedsides, should nature call...
Feb 22, 2006. 11:08 PMbub4280 says:
The brass wind instrument makers used pitch to fill the tube prior to bending. Easier to find and cheaper than wood's metal. low cadmium content, too. Nice earthy smell, too.
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:PaulE
