3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to bend tubing
Step 4Ready to bend
Ready to bend
Here, you can see that I take a piece of scrap (from the earlier cut) and attach it to the table to complete the jig.
You will want to bend from one side only while ensuring the tubing is supported wile bending. While bending, try to keep the pressure against the jig instead of the tubing.
You may want to practice with some cheap amluminum conduit to get the hang of it. When you are ready, get the polished stuff.
Have fun.
11 comments
Apr 5, 2010. 11:34 AMEvox_Rider says:
I have been looking for alternatives to buying conduit benders (they are not cheap...and I am...lol).  Would doing a jig like this, but for a small 3 or 4 inch radius work for 1/2" conduit? or would it kink?
Oct 5, 2011. 7:12 AMGreyBird says:
I use a spring to bent PVC Conduit. For long pipes I attach a rope on the one end and shove it down the pvc until it is in place. My spring was inexpensive. Hope this helps.
Apr 5, 2010. 5:21 PMEvox_Rider says:
 I was thinking if it does kink, to try and make a groove in the edge of the half circle part to match the conduit (thinking to maybe mount the full circle into the drill press and use it as a makeshift lathe)
Sep 22, 2009. 9:04 AMjcmaner says:
if you fill the conduit with sand it will not kink
Jul 4, 2006. 2:44 PMScott Dallesasse says:
How about just going and buying the right size conduit bender?
May 24, 2007. 9:08 PMPaulcet says:
Conduit benders are fixed-radius, but with the wood form it can be any radius you want, even varying radius.
Sep 22, 2006. 10:25 AMDiamondBack says:
a conduit bender bends pipe. While you can get aluminum pipe, this how-to talks about bending tubing. If you were to attempt to bend tubing in a pipe bender, you would end up putting a serious kink in the tubing - rendering it unattractive, and useless But, doing this rail WITH conduit, and the conduit bender, might be a viable alternative. Polish it up with 2-3 grades of emery cloth, and it could look quite attractive
Apr 9, 2007. 2:49 PMbethehammer says:
Add a torch and this is a good way to bend steel tubing/pipe also...
Mar 20, 2006. 2:38 AMReaper says:
Great little compression bender there. As others have mentioned, packing sand in the middle of the tube will help reduce deformation. Freezing water in aluminium won't! The other big thing to a good job is get a bending grade of aluminium. The difference is in the alloy and the temper - some bends better than others, check with your aluminium supplier, they should be able to point you in the right direction.
Jan 22, 2006. 9:59 PMTrunin says:
Another great way to bend the tube is to fill it with sand. (Make sure that you have a good fill with no air pockets) Cap the ends and you can bend all day with no kinks. You can do the same thing with water, however even a small air bubble will allow the tube to fail.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:PaulE
