I know that there are other instructables on the art of book binding but this project is meant to be a simple quick project that will give a very acceptable finish and a book that looks like it has been professional made, yet without the need for any special equipment.
All you will need is:
Some paper
minimum really is about 32 A4 or US Letter sized sheets, to make a half A4 (half US Letter sized book), although small books can be made as can ones with more pages. You can use tracing paper, thick or thin paper and of course colored or even preprinted or written on paper.
Some glue
You will need PVA (Elmer's White glue) or a rubber fabric adhesive (in the UK that is called Copydex, perhaps someone could tell me what it's called in the US), (a glue gun if you have it, would help with one of the stages, but is not mandatory)
Some stiff cardboard or corrugated (fluted) cardboard
Some fabric or leather
Any old stuff will do for the cover. I have used the fabric from some old pairs of trousers that were being thrown out (actually nothing gets thrown out in my house, just put to one side for later use). But you could use a bit of leather, some old curtains, cushion covers...etc etc, I'm sure you get the idea.
Step 1: Stack your paper neatly in (at least 4) piles of 8 sheets
Your book should have at least 4 or these 8 sheet folios which will therefore make 128 pages. (apologies to all the maths wizards out there).
You can use just plain paper or paper upon which you have already printed a header and footer (remember to get this the right way round and remember that there will be 4 headers and four footers per sheet of paper.
If you want to mix in different papers then remember that they will appear further into the book as well. (don't worry, this all becomes obvious as we go through the project).
Step 2: Fold each stack in half
Step 3: Unfold the paper and turn over
Step 4: Staple the pages together
Open out your stapler
Place the upturned paper stack on top of an eraser (positioned where you want to staple) (which will be about 2 inches from the edge of the page exactly on the crease) and slowly but firmly push down on the stapler until you have stapled the pages.
Turn over the pages and pull off the eraser and then fold over the staple ends with the blunt end of a dinner knife or your thumb nail being careful not to break it / stab yourself.
Repeat at the other end of the crease so that each page has just 2 staples in it.
If you, like me have a long arm stapler, simply staple the 8 sheet stack in two places... I knew there was a good reason for borrowing that thing from work.
Step 5: Glue the binding onto the folios
Firstly , cut a piece of thin fabric to the same length as the page height and about 5 times the thickness of all the folios held together.
Hold the folios tightly together and all lined up. Either get a friend to help or clip the folios together using giant paper clips or bull dog clips (or even a rubber band I guess).
When they are all nicely aligned apply glue to just the spines of the folios. You can use White glue for this (this was what white glue was originally made for) but you must be careful not to let it drip down in to the gaps between the folios (maybe painting the fabric would be better.) Alternatively you can use hot melt for this part. Again, hot melt is used in industry for book binding, so it is perfect for the job.
Befroe it has a chance to set quickly turn over the wad of folios and glue them to the piece of fabric so that some fabric sticks out each side (i.e. that is not glue to the pages)
Step 6: Trim the bound folios
If you want (and you don't have to) you can trim the folios a tiny bit. Beware that the first time you do this you might end up making more of a mess of the edge of the paper than if you just left it. It takes a bit of practice and a sharp craft knife or scalpel (definitely NOT something for children to do on their own).
If you want to trim, then the most important edge to trim is the edge opposite the binding, because when the paper is folded over all the pages get to be slightly different lengths depending on where they are in the folio stack.
The trick is to hold the rule very steady and take many repeated cuts being careful to cut in the same groove and try to make sure that at each cut the paper on at least one layer is cut from edge to edge. (BTW I know that the drawing I have done to illustrate this step does not show this method of trimming multiple sheets, but it is meant to be a bit figurative anyway).
If you have access to a proper guillotine that can cut through paper stacks (i.e. at work or at school) then this is the time to use that, it will give you the most awesome finish).
Trimming is by no means necessary.
Trimming or not, you have now finished the paper part of the book and it's time to move on to the cover...
Step 7: Mark and cut out the cover boards
Cut the card out and then cut a duplicate.
Corrugated card is fine as the cover, as is thin foam core (foamboard), but the best kind of card is the stiff card that is used as the backing for drawing and sketching pads.
Step 8: Make the book spine
Cut the spine so that it is the thickness of the covers and the paper together and the same length as the height of the book covers.
Step 9: Mark and cut the material
Cut out the material.
As already mentioned, you can use any material you want really, although very thick material will be difficult to fold and glue (although, who knows how patient you are?).
Actually, I used material from a pair of my ex-wife's linen (Toast) trousers, thought I might give her the book as a Christmas present in an ironic sort of way... don't worry only joking and she had thrown them out anyway...
Step 10: Glue the cover board and spine in place
Make sure you stick them neatly in a row so that they are aligned with each other and straight and that there is a gap of about 1 or two thicknesses of the card you are using between the spine and each of the cover boards.
Step 11: Finish the edges of the cover
Step 12: Glue the paper into the covers
Smear some white glue (or rubber solution glue) in two stripes down the middle edges of the cover boards being careful not to get any glue on the spine board.
Then place the bound paper wad so that it is centrally resting on the spine board and ONLY the thing cotton "wings" are glued to the cover boards.
The spine should NOT be glued to the bound paper wad, although you should make sure that it IS glued to the cover boards right up to their edges, because this is the join that makes the book strong and stops the page block falling out of the cover.
It is best if you wait for this part to dry before moving on to the next step. It is probably a good idea to leave the book lying on its back with the paper was supported by to food cans while it dries, because, if you leave it to dry closed, bits of it might stick together that you don't want sticking together.
Step 13: Cut out your lining paper
For the lining paper you can use almost any type of paper. Traditionally Marbled Paper was used. Now you can make this yourself (hey, I feel another Instructable coming on already) or buy it in sheet form from most good craft shops, or download a sheet of marbled paper from my site (where you'll see loads of other projects just like this). Or alternatively you can use a bit of old gift wrapping paper, or even just plain old brown packing paper. be as creative as you can here, the lining paper is like the lining of an expensive suit... hidden until it is revealed by someone opening it...
Ideally you want the lining paper to be a fraction smaller than the paper wad's height so that you can line it up neatly and twice as long as the paper wad's width so that it covers the inside of the hard cover. (see next step).
Step 14: Glue the lining in place
Smear the inside of the cover and the first page with white glue or rubber solution glue.
Carefully place one half of the folded lining paper on the glued first page so that it lines up neatly with the edge of the paper. Then Making sure that it goes in to the corner of the join between the paper and the cover fold the liner out and glue it to the inside of the cover so that it covers up all the folded over material and the inside of the cardboard covers.
Repeat for the back of the book.
That's it... you're done.
If the first paper goes a bit wrinkly as it dries out, wait for at least a day for it to dry really thoroughly and then iron over the page using a medium iron. It won't get all the wrinkles out but it will make the page a whole lot flatter and just try to use a bit less glue for the next book.
Step 15: Experiment and make loads of different books
I have made a couple more so far. I made the jeans one with a pocket after my niece, Josie suggested that I use the pockets from the trousers for pens and stuff... neat I thought, and it seems to work rather well.
See what you can come up with and if you make something you like, why not post the images here or email them to me and I will put them up on line on dadcando
Visit Our Store »
Go Pro Today »
www.talasonline.com
Great 'ible by the way, I'll share some photos when I'm done
I went off your guide a little bit to give the insides of the covers a decorative twist. As you can see, I added a bookmark and I am so pleased with the results!
Anyway, here's the album with five pictures of what my book looks like! Thank you, again!
-Ilsa
http://s1200.beta.photobucket.com/user/Ilsa7/library/Handmade%20Book
I designated each of the 8 pages A-H and number each side before folding 1-4 in the upper corner of the page (1&2 on first side, 3&4 on backside). Then folded, the order came out as predicted so I think this works:
A2, A3, B2, B3, C2, C3, D2, D3, E2, E3, F2, F3, G2, G3, H2, H3, H4, H1, G4, G1, F4, F1, E4, E1, D4, D1, C4, C1, B4, B1, A4, A1
I've been unsuccessful locating any templates out there so far, so my plan is to set things up in landscape (2 columns) with margins enough to accomodate the spine and trimming and save the blank file as a template. Write the book (I'm writing down childhood memories for my sister for christmas) and make sure I don't go over the allotted pages including a title page and forward. Then copy the pages individually in the above order leaving a blank spot at the bottom for page numbers (remember even letters the page number should be on the right and odd numbered letters on the left).
Then print it all out front and back. It's a lot of work, so if anyone has an easier method, please let me know!!
I was wondering if there was a way to create my own ruled paper, as it would be very useful for me. Many websites DO in fact, offer templates, but none of them fit my need, and I was wondering if it was possible to do so with MS Word or Excel.
Oh, and I forgot to thank you for this wonderful instructable. Thanks a million!
A little tiny one. It came out GREAT, used foe leather as the cover.
A tip for anyone who wants to make one. If you clamp the pages very close to the edge then run it on a belt sander "with the grain" it makes a very nice smooth edge. You have to run it across the grain very quickly on each side to get rid of any little paper shreds.
I have bought it cheaply in large sizes from a local paper supplier's office warehouse.
It's not difficult, but it does take time.
I don't think you could use tacky paper, but you could try perfect binding if you don't want to fold the pages. Perfect binding is when you get all the paper together in a neat stack and then glue one edge of it. This is how nearly all novels are bound when they are in paperback form.
Minor edit: Step 6, "Befroe" -> "Before"
I have a soft, very pliable piece of leather. Is it advisable to use cardboard, also, as shown above, to make it stronger? Or would it be okay to repair the cover, glue the binding and then glue the inside sheets to front and back.
I also am very impressed with this explanation! I've looked at several that were very confusing.
will this be able to be used for 600-1000 page books? :D
also, instead of fabric can i use paper for a custom cover?
Thank You
Elephantswind.wordpress.com
Might be thick here- but l dont understand the Folio bit what is the folio bit and do you stick a folio to each page ?? confused
