3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to bind your own Hardback Book
Step 10Glue the cover board and spine in place
Using White glue or rubber solution glue, smear an even coating over the boards and place face down on the wrong side of the material (i.e. the side of the material that you don't normally see, which has the pattern the wrong way round etc etc).
Make sure you stick them neatly in a row so that they are aligned with each other and straight and that there is a gap of about 1 or two thicknesses of the card you are using between the spine and each of the cover boards.
2 comments
Mar 9, 2011. 3:25 PMnjenkins says:
I recently made my own hardbound book without the help of this tutorial (I wish I had known about it!), and I found that using a spray glue for the cover, be it fabric or otherwise, works waaaay better and you don't have to worry about using too much and the covers looking wrinkled! The spray glue itself is pretty inexpensive, about $5 at my local craft store, and you can use it for tons of other projects too!
Apr 17, 2011. 11:01 AMtcarney57 says:
3M has some archival-quality spray adhesives, but rubber cement is well-know for leaching sulphurous compounds that eventually stain whatever it's used on--it completely ruins photographs! I actually like rubber cement because you can reposition things fairly easily, but I never use it on anything I want to keep for more than a few months. Again, I think the scrap-book folks might have plenty of good suggestions for archivally-safe adhesives.
Feb 12, 2011. 8:25 PMtruthlikegold says:
Depending on the material, you might want to use a very thin layer of the glue, as the fabric I used for my first book had bleed-through issues when I was too (unknowingly) liberal with the white glue.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
333
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
