How to Bleed and Restart Your Oil Heating.
Published
Introduction: How to Bleed and Restart Your Oil Heating.
About: A Northern Ireland based maker with a propensity to cause trouble and freshly constructed family.
A guide to restarting oil heating boilers after they've been off for a while or the oil has run out.
Yeah, I've been getting to do plenty of this lately.
A lot of people don't know how to do this when they first move out or in to a house with oil heating after they've used gas or electric all their lives...
Step 1: To the Boiler...
Go to the oil tank and make sure there's oil in it, or you'll be wasting your time...
You'll need either a small spanner or Allen key, in my case it's an Allen key.
There'll be a red button, often lit up on the front. Make sure the heating system is in the "on" cycle and press the button, the boiler will start doing things and trying to fire up.
Don't be too disappointed, it's very rare for you to get lucky but it has happened to me and it seems to help get the fuel moving a little bit.
Step 2: Bleed the Line.
You'll need to find the bleed nut/plug, it's on the front of the boiler but may not be too obvious, it'll usually be a rubbery plug, once you've located it you'll need to unscrew it.
Fuel will begin to dribble out along with air, let it dribble until it's at a steady rate of flow.
Screw the plug back in but not completely tight, just in until it stops dripping, press the button and cross your fingers.
It didn't fire? No worries repeat the bleeding process again, it can take up to ten goes. If you do find it always takes a huge number of turns to start again you may need to replace the in line filter.
Step 3: Starting Up?
You'll know it starts because you'll hear the sudden thump as it starts burning and you'll hear that dull roar, also you'll be able to see in the pilot window - if you watch the exhaust when it's firing you can also check for pinhole leaks because little embers will pop away from it...
Depending on your boiler you'll need to figure out if your bleed plug has to be fully tightened or just left tight-ish. On most of the boilers from houses we've lived in its been that you don't leave it dead tight but in this one you have to tighten it all the way or the boiler slowly takes in little bubbles of air and eventually dies.
Basically the easiest way of telling is to fire it up with the bleed plug almost fully tight, if it coughs and dies after a while press the button, let it run for five minutes and then tighten fully.
Step 4: Enjoy Being Warm.
I didn't get to several times due to the epic failure of different bits of the heating system, now it's running alright after heavy tinkering with all the valves to get it burning again - reasonably sure the main issue was water vapour in the boiler of some in the fuel line, all fixed now, though I need to fix the exhaust cover, the flat bits fallen off and it's wasting energy, however I can't remove the cage until I have a replacement, the cages rust away very fast due to heat and water vapour from burning fuel...
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    22 Comments
    Hi i filled the half tank kerosine oil on the 12/07/2016.now the timer is on with red light that mean on but I don't hear that the electric motor is on.could any one let me know whether motor should start or not or wat it could be.?
    I just bought a mountain cabin in Maine and this was a great help! Ive never used a kerosene/oil tank heating system before. I had them fill the tank before I got up here but couldn't figure it out until now. I pressed the red button and it fired up beautifully. Thank you!
    unfortunately this did not work for me the redlight is just that a light not a pressable button any other ideas please
    BRILLIANT - worked first time once I pushed the red button thankfully - saved us a call out charge so thanks
    Hi - could anyone please tell me the minimum amount of Kerosene I woudl need to buy to test a boiler. I am thinking the boiler is not working so do not want to spend money buying lots of Kerosene until it is fixed or replaced as will not use heating until December really - help - just want enough to be able to test the system?
    Check the tank, you can tip them a bit towards the outlet a little - just don't strain the connector, a 25L "emergency or topup" drum should get you going if there's not enough for a test with it tipped, plus it's kind of hard to buy it in lower quantities.
    If the cap's been off the tank any length of time it'll need drained first though...
    Do you leave the boiler on while doing this?
    Thank you, worked brilliantly for me after couple of trials
    Bleeding brilliant - now the wife doesn't have to know we ran out of oil! Many thanks.
    Thank you for your explanation. I managed to restart the system , Catherine :-)
    Thanks alot.Kept bleeding the system and now got it working! As a newbie to oil systems this was a great help..now have heating for xmas!
    F...King fantastic. It took a few more than 10 attempts but I just persevered and it worked! simple sound advice
    My local heater specialist charged me £100 each visit.. This has saved me potentially and literally 1000s
    A BIG Thank You!
    at first, wheni read the title, i thought it said how to bleed.....lol....pretty good 'ible
    Yes...it will be very short- "allow yourself to be distracted while manipulating machine with edges, great mass or momentum..." LOL!
    SURE!!!! :P
    the basics...awesome! This 'ible epitomizes 'Instructables'...how to manipulate everyday machines! Thank you for sharing.
