Introduction: How to Bolt the Foldy Mech on a Razor Pro Scooter
You are probably wondering what the hell is a foldy mech well its just a shorter word for the little lever you push down and that makes it fold.
There are good things about the foldy mech like 1-the most obvious you can fold it,but over time it bends from constant use.
But not if you bolt it which is what I'm going to teach you how to do.
If you do it right then it will be even better then before.
Step 1: Materials
1-Razor PRO model scooter.
2-Regular tools (screwdriver,wrench,etc).
3-Most important--- 1 3/8 inch bolt, Has to be 3 inches long. 1 of these. with nuts. lol but seriously
4-Most important--- 2 5/16 inch bolts, Has to be 3 inches long. 2 of these. with nuts.
5- 6 lock washers + 6 regular washers
Thats all
I went to home depot to get the parts and it came out around 6 bucks which is really expensive for just 3 bolts and some washers. But it is extremely worth it.
Step 2: Take Out Old Hardware
1-push the first pin out
2-you have to bend the carter pins up with a screw driver and then it just slides off
look at the pictures for help
Step 3: Install New Hardware
1-get your new bolts
2- Put 2 lock washers and 2 regular washers on every bolt.
3-Slide the bolts thru the foldy mech in this order---
lock washer,washer,other side of bolt -washer, lock washer
Just look at the pictures you dummies
Step 4: Tighten It Like Never Before
Just put the socket on and the wrench and tighten the bolts pretty tight .
Ride away
