How to Boot Linux From USB
87,637
30
Published
Introduction: How to Boot Linux From USB
Your hard drive sometimes crashes and you have to use the computer. This instrable will show you how to boot Linux from your USB.
Step 1: Things You'll Need...
-A minimum 512 MB USB
-A lightweight Linux OS. I' ll use Puppy Linux
-A USB Creator Tool ( ill use Linux Lilli )
Step 2: Download Linux OS
You can download Puppy Linux frome here. You can also use any other OS if you want to.
Step 3: Download USB Creator Tool
You can download Linux Lili from here. You can also use any other tool if you want to.
Step 4: Format Your Pen Drive in FAT32 Format
Connect your USB to the computer. Right click your pen drive in My Computer and click on Format. In File System, click FAT32 and click on Start. Then click on OK. Let the fromat complete.
Step 5: Linux Lili
Run Linux Lili and select you Puppy Linux ISO File from where you had downloaded it. Mark on " Hide Created Files on Key" and "Format The Key in FAT 32" . Then click on the lightning icon to start the isntallation.
Step 6: Boot
That's it now restart your PC to boot the Linux OS. Press Boot Key ( F8, F12. Del etc ) and select you Pen Drive to boot the OS!
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    3 Comments
    when I do this, if I save images and other files while on the linux instead of windows will it save to the drive or the USB stick?
    I can never get the option to pull up the boot menu
    I need to do this instead of burning CDs every time I want to check out a new Puppy. Never heard of Linux Lili, but it looks easy enough... Thanks for sharing this option!
