How to Build Project Blaster Knex Ball Machine
7,846
15
111
Published
Introduction: How to Build Project Blaster Knex Ball Machine
About: I'm a 16 year-old guy who loves to build mechanics out of knex. my main interests are ball machines and roller coasters. My real name is Matt and I'm a christian. I live in Australia or more commonly known a...
I've always loved knex ball machines and this is my second ball machine on the site. Project Blaster uses quite a few pieces. I estimate that it will take you about 3 hours to complete. It has three of my own elements and two of them are new. The See-saw and the slithering path (which is a type of path).
Here is a picture:
Step 1: Main Tower Base
This is where everything starts. Two gears are placed in this step. Just follow the pictures and read the notes. Check that the 3-D connectors are placed in the correct direction.
Step 2: The Base
This is the section where the rest of the path goes and where the second tower connects. After connecting this to the tower base it will be 12 blue rods long.
Step 3: Main Tower
 The main tower is where you attach the chain lift. The gears at the end of the step are used so that the chain doesn't move all the time. It is not the top of the model.
Step 4: Secondary Tower
The secondary tower has two main functions:
1. To hold the path alternators
2. Support
After you finish this section it should look like a fat U.
Step 5: The See-Saw
This is a new element I designed. The ball falls on one of the sides and the see-saw makes it land in a drop.Then the see-saw teeters back and forth for about 13 seconds.
Step 6: Main Tower Top
This is the section that contains the motor and the path separators. I'm sure you could substitute the motor for any other type of motor.
Step 7: Pendulum Slide
This is my own element. It is not a new one because I used it in temple of demise. The ball rolls down the track hitting each pendulum making them move back and forth.
Step 8: Connecting the Towers
This part is needed not just to hold the towers together but also to hold the slither path. It is a pretty small step.
Step 9: Slither Path and Criss-Cross
The slither path is another new element that I made up. Personally, I think it looks really cool. I also included the Criss-Cross. An element that I have seen on many ball machines.
Step 10: Ferris Wheel and Spiral Staircase
The ferris wheel is the only element on path 1 apart from the path. After adding the spiral staircase path 4 will be complete. Now its starting to look like a ball machine.
Step 11: Orange Path
You are very close to finishing. After this the only thing you will need are some paths to connect everything.
Step 12: Element Connectors
These are a set of paths that connect the elements to the bottom and other elements. There are 4 of them. So if you have less you followed the instructions wrong.
Step 13: Chain Lift Attachment
After attaching the chain lift project blaster will be complete.
Step 14: Your Done
Congratulations! You have just completed project blaster. If you have any questions don't be afraid to ask.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    111 Comments
    count them...
    Because I'm nice...
    26... I think.
    NO I double checked there are 26. besides. Back then I only had 26...
    i triple checked there are 42 and temple of demise uses over 55 so are these ball machines really yours??
    BACK THEN I had 26. I have more now. Maybe I was wrong. Well now you know that you don't have enough.
    This was a year ago. I don't have a piece count. :-P
