Step 2Getting started!
I assume you're using LEDs with a 3.3v forward voltage drop. In fact, the entire project uses that assumption. Adjust your numbers accordingly if that's not true for you.
You will solder down 16 rows of 4 LEDs, so stuff the first row in to the board. You'll connect these positive to negative down the row, so make sure they all point the same direction.
Add Comment
