Remove these ads by
Signing UpStep 1Why and how
This project took about 3 months of research and development (not counting waiting for parts to come in or help from a friend with the welding). All in all, it cost about $3000 to buy and build. This may take a long time to pay off in gas savings, but if you add the fun of building and all of the environmental benefits, it was well worth the effort. With a top speed of over 70 mph and 10 miles per charge, this vehicle is perfect for me. The following instructable will not give you exact step by step instructions, but if you have some mechanical skills and welding ability you should be okay. A little knowledge of motorcycle maintenance wouldn't hurt, too. However, I just read the user's manual and learned as I went.
This is a great write-up on how to register your bike.
Cheers!
- Charles
Thanks
gdoherty0@gmail.com
http://25.media.tumblr.com/tumblr_m45g8hZaBS1qkbchho1_1280.jpg
Thanks!
congrats man, u done a great job.
i'm totally impressed & wanna take u as my inspiration because from many years i'm planning to do such model but unfortunately i dint find a way to start it.
after knowing reading ur process, i'm happy to tell u that even i'm going to start like ur model & procedure but 1 change in it.
so, can u help me out in this?
reply to-nittingautam@gmail.com
Wait a minute... is this kim dotcom?
How many HP is the motor?
Top speed?
The Second Law of thermodynamics essentially says that energy exhibits entropy. It moves away form its source. In machine terms, you have to add energy to get more work, and the ratio of energy to work will never equal 100% due to energy expanding away from its source.
Solar pannels are a good source of energy used to get work but all other forms of "self recharging" through a mechanical means would require work and energy of a greater amount that it would produce.
Is there any possible of regenerating in E-bike.
but still, we both agree it's not going to create perpetual motion.
magnetos work so well with 'those old dirt bikes' because a gas engine creates tons of energy, much more than needed to get you down the road.
off course, you could always peddal :) lol
If you want to increase range a little more, additional methods include:
- use a brushless motor
- get the best batteries you can. Absorbed glass mat (AGM) aren't quite the pinnacle, but they can't leak and some have good capacities
- consider small, flexible solar panels that can conform to top-facing surfaces like top of fuel tank, ducktail etc. Trickle-charge a little while parked!
- consider these little buggers: http://www.dealextreme.com/p/wind-powered-led-light-for-vehicles-2-pack-5172
Might seem silly, but my idea was to place these tiny wind generators in fairing gaps (where airflow to voltage controller etc would not be affected).
So maybe 6 or 8 of these little guys, (of course you removed the leds) to divert the energy produced into an auxiliary channel of the charging circuit.
It could work!
...but click the link provided ^
These are tiny, lightweight plastic items that represent NO parasitic loss. They're designed for bicycle or car exterior and as they spin, generate something like 1V (if that) to illuminate one LED.
If the air is passing through a vent anyway, why not use it?
By themselves, the little wind powered LEDs *do* have a degree of inefficiency, as they don't use high quality bearings etc. Yes, there is some friction.
In the context of the overall project though, you're getting a bit of electricity for what? Negligible wind resistance.
Using your argument, you'd also oppose the use of a capacitor to store static electricity from the riders body. Well, the cap *weighs* something doesn't it? lol
Solar cells small enough to not effect the shape of the vehicle are not powerful enough to drive it.
Because of losses in each step of transformation, of wind energy to electric energy to chemical energy (battery) to electric energy to moving energy again, and losses in storage. It is clear that no equipment attached to moving vehicle, and driven by it´s movement, will ever cause it to go faster or further. If it could, we'd have solved humankind's energy problems.
