Step 2Components and tools
Frame: I looked at many different bike styles and decided on a 1984 Honda Interceptor for a few reasons:
1) I like the style of bike, not a total crotch rocket but not a hog either, with room for batteries inside the frame.
2) The seller on Ebay was close to my house. And the bike didn't run, so it only cost $600. If you have an old bike or someone will donate one then that's great--but for the rest of us, try the local paper, junk yards, Craig's List or ebay motors.
Motor: After reading other EV bike specs (and knowing that I wanted to go faster than a moped), I chose a 72V Advanced DC motor, because it's weight and dimensions where good for my frame. I ordered it online fromthunderstruck-ev.com.
Batteries: I went with 6 Yellow Top Optima batteries from remybattery.com because they are sealed and have received great reviews. After making cardboard mock ups of the D23 model I realized that there was no way six full sized batteries would fit and still look good. I ended up getting the D51 model. Half the size and weight but also half the storage.
Controller: You have to match your controller to your voltage but the amperage is up to your budget. More amps = more power and more cost. It seems that there are only two real choices: Alltrax or Curtis. You'll have to decide for yourself, but I went with the 72V 450Amp Alltrax from cloudelectric. Don't waste your time trying to build a potimeter on an old throttle--just buy a pre-made one and be done with it. I got the Magura 0-5K Twist grip throttle from cloudelectric.com
Charger: You have to match your charger with your voltage but the speed of charge in Amps is also up to your budget. I went with a Zivan NG1 from EVAMERICA I have recently switched to six individual 3amp Soneil chargers to help balance the batteries.
DC/DC Converter: It's safest to run with a DC/DC converter and an extra 12V battery backup but motorcycles have limited space so I am only using the converter. I purchased a Sevcon 72V Input 13.5V output from evparts and it has working perfectly.
Fuses: You'll want to get a fuse that matches your setup. I bought model ANN 400 w/ holder from EVAMERICA.
Contactor: This is a device that you hook up to your existing key ignition on 12Volts and it will close the loop so you get the full power to your controller. I bought an Albright SW-200 from EVAMERICA
Battery cable and connectors- I bought about 10 feet of 2 GA wire from WAL-MART and cut it to length. Using Lugs from cloudelectric I soldered and used heat shrink tubing on each end. I highly recommend battery terminal covers for safety.
Instruments I chose an E-meter(Link 10) w/ Prescaler add on for 72V use instead of a bunch of different meters. As an added feature I wired up the ignition switch to the neutral indicator to show me when the bike was on.
Other parts
Wire - 12GA different colors and heat shrink tubing (large and small sizes)
Electrical tape
Wire connectors
Wire wrap
Tools
Basic shop tools are required such as a socket set, screw drivers,wire stripper, etc. Additionally a volt meter, metal grinder and crimper are used in this project.
Is there any possible of regenerating in E-bike.
Sorry about the late reply, been away from the site for awhile.
"The wheel you spoke of is simply called a water wheel, though there might be another (more proper) term.
but yeah, the type of engine you spoke of originally has actually been produced, and soon is supposed to be commercially made, although it's actually a pneumatic engine that refills it's tanks when plugged in. :D sounds pretty sweet to me
You would need an external source of energy input into the system while driving.
It would be possible with large scale technology similar to the proximity charging devices we have recently developed for small electronics. But the cost to create such tech on a large enough scale to charge while on roadways is not feasible at this time.
Could you provide me a link to some documentation that says an alternator has better low RPM efficiency? My research in wind turbines suggested that at best, alternators and generators have the same efficiency at low speeds, and most seemed to agree that generators are better at low RPM.
A transistor controlled ground is one more part, and a much cheaper, easier, smaller and lighter one to install than an alternator. I suspect it would also be difficult to find an alternator that can output this kind of voltage. Many have a fixed regulator that won't allow excess voltage in the event that the computer controlled one malfunctions and full-fields, and even one without that protection probably isn't built to output this voltage and may fail prematurely. Even on a car where the alternator is typically driven at approximately 3-5 times faster than the crankshaft, the voltage will drop to below the desired charge voltage with only a few amps drawn at idle 500-1100 RPM (1500 to 5500 RPM at the alternator). So that alternator designed to output 12 or 24 volts would have to be geared up considerably, further adding weight and frictional losses from the gears. An additional load on the motor would require more power from the motor to spin it up to speed. Try spinning one by hand, the rotational mass alone would take considerable power to get moving, especially with the gearing required to spin it fast enough to make this high a voltage.
Also, regenerative charging using a brushless will most likely require a weird bridge rectifier (3 phase+) with a negative feedback loop.
Loud pipes are a great lifesaving safety device. Also, I loved reving my engine and dround out the crappy noise that passes as music. I'd probably still laugh at the guy for making an imitation Harley noise. Most Harley owners would be offended. Play another engine....Perhaps the sound the rice-racer cars with the oversized exhaust (it kinda sounds like the muffler broke off....lol
