Probably you have reached this page because you have seen one of the video clips on led cubes, which are spread in the internet, and you have decided to build one by yourself.
Well, I am happy to let you know that you have got to the right place. Here you will find my notes, the pictures for crafting, the source code for the software that I developed for controlling the cube, and many demonstration videos.
Before you start, please read the whole instructable. This is advisable to have a global view of the project.
Prior to enter in the practical steps, a short theoretical introduction is necessary to well understand what we are talking about.
How the cube is made:
The dimensions of the cube will be 8 led by 8 led, by 8 led, for a total of 512 leds. The whole structure will be based on a wood board.
The concept of persistence of vision:
In this project we will exploit the persistence of vision. This phenomenon is a feature of the human eye and is responsible for the illusion that a movie is not composed by individual still images. All the animations are based on this biological dis-functioning of the human eye. If we can switch on and off the leds in a sufficiently quick time, (a few milliseconds) they will appear as if they were simultaneously on.
We use the persistence of vision because simultaneously switching all the cube leds on would require a very high electric current (in ampere). Actually, if we consider that the high brightness leds of this project require about 20 mA, we can calculate that 512 leds would require 10.24 A. This high current is hard to manage. So, what we do? We switch on a cube layer at each time! In this way the current consumption will never exceed 1.28 A (20 mA x 64 leds), which is easily supplied by a good voltage transformer. Let us suppose that we want to make the cube appear as completely switched on. To achieve that we simply have to switch on the different layers one by one at high speed. To a human eye the cube will appear as completely lighted.
How to control each led:
In order to independently control each led, we divide the cube into horizontal layers and vertical columns.
All the leds of a horizontal layer will have the cathodic contact (-) in common.
All the leds of a vertical column will have the anodic contact (+) in common.
Overall, it will be necessary to control 8 cathodic contacts to select the layers and 64 anodic contacts to select the columns. The combination layers by column will select and switch a single led.
The 8-bit shift registers:
The shift registers are composed by 1-bit memory cells connected one each other. At each clock impulse, they allow the bit flowing from a cell to the next-one. The registers used in this project are SIPO (serial input-parallel output) type. The data are charged one by one through the input bits and the output bits are simultaneously collected from the 8 outlets.
Power supply':
To power the cube and the control circuit it is necessary a power supplier with the following specifications:
- voltage: 5 volts (stabilized)
- current: 2 ampere (4 is better)
Pictures:
The finished cube functioning.
Remove these ads by
Signing UpStep 1Let us build the real cube (first part)
- Soldering iron
- Soldering tin alloy
- Hot glue gun
- Jigsaw
Needed materials:
- 512 leds of your favourite colour
- 1 40 pin flat cable (to connect the IDE hard disk to the pc)
- 1 34 pin flat cable (to connect floppy disk to the PC)
- 1 prototype board
- 1 plywood board 20x20 cm, 8 mm thick
- Electric wire suitable for soldering (thin, flexible, and resistant)
Building:
Draw a 7x7 square grid (2.5 cm side) on the the plywood board. At the crossings of the grid lines drill 64 holes with a mesh diameter as the led size, generally 5 mm. This board will be the basis on which all the leds will be soldered. By this solid grid the leds will be evenly spaced and perfectly aligned. As explained in the intro, the cathodic contacts of each layer will be joint together. Insert the 64 leds in the board holes and bend the cathodic (-) terminal to obtain an interconnected grid.
SEE IMG. 02.1 AND 02.2
Let go out the board holes only one led terminal. It will control the layer.
Attention! Each time you finish soldering a layer, test each single led. It is convenient to discover early if a led is burned out or not well soldered.
SEE IMG. 03.1 AND 03.2 AND 03.3
Make 8 identical grids, paying attention that the led terminals going out of the board have a different orientation for each layer.
SEE IMG. 04
![Hard Wired LED Cube: [No Programming]](http://img.instructables.com/files/deriv/FTD/SF1T/GO8DC8KW/FTDSF1TGO8DC8KW.SQUARE.jpg)
Also, you are using 100 ohm resistors with the intention of getting 20ma per LED. This is too much. Each shift register can only handle 50ma TOTAL so with eight outputs you should not be putting more than 6.25 ma out per pin meaning 330 ohm resistors are a better choice.
I think you got lucky and the current limit provided by the layer transistors is dropping it enough to stop you from blowing your shift registers, I suspect the LEDs are not actually running anywhere near the calculated 20ma each.
I have a few doubts, if you allow me..
- Can I start/control it from a web browser (chrome, i.e., etc..)?
- If I put some sensors on it, it is possible to "trigger" it when someone walks into the room?
Thanks!!!
Meu email é : lucianobr37@yahoo.com.br
Obrigado.
But Im thinking how let it make easily!
Im starting.I want do it.thanx.....
Why not connect each shift register to a pin on the parallel port - you have plenty extra - and load all the first bits for each register at once, then the second bit, then the third, etc. It should be 8 times faster.
thanx
Did this Circuit doesnt need a VCC connection to work?
The only positive volt connection is just on the led, and nowhere else.
the shift register needs vcc too, but Pin 14 is nowhere connected
let's start with a Soldering robot project :D
The single circuit left I do not understand.
Could someone maybe able to explain what that meant?
Thank you
http://www.instructables.com/id/How-to-build-an-8x8x8-LED-cube-and-control-it-with/
grazie per i complimenti...
la versione in italiano puoi trovarla a questo link: http://www.instructables.com/id/Come-costruire-un-led-cube-8x8x8/
Per quanto riguarda i led a poco prezzo io li ho presi su ebay, 500 led blu a 50 euro. Se hai bisogno posso anche darti il nome del venditore..
ciao, Matteo
