Step 3Build the control circuit (first part)
The control circuit is basically composed of:
- 8 shift registers of 8 bits (total 64 bits) that enable / disable each column of the cube
- 1 shift register connected to 8 NPN transistor to enable / disable each layer.
- 2 connectors with 40 and 34 pins for connection to the cube
- 1 connector with 2 pins for connection to the parallel port
Why do we connect the 8 NPN transistor to the shift register of layers? As we know, the leds of each layer have a common cathode (-), then we must enable them to connect the signal mass. The problem is that the output of the layer shift register have a high level signal (logic level 1 is equivalent to Vcc) in any pin enabled. We need a component that, given a signal at logic level 1, enables the passage of the current. This component is the transistor. It works as a switch: if the pin of the base is set to logic level 1, the pin collectors and emitter are connected together.
Tools needed:
- Soldering iron
- Soldering tin alloy
- Pincers
Materials needed:
- 9 shift register of 8 bit (I have used 74HC164B)
- 9 slots for shift register
- 8 NPN transistor (I have used 2N3904)
- 70 resistors 100 ohm
- 8 resistors 1500 ohm
- 1 prototype board
- 2 connectors with 40 and 34 pins for connecting to the cube
- 1 connector with 12 pins for connection to the parallel port
- 3 connectors with 2 pins for connecting the power switch, the led power and power supply
- 1 red / green led (power led)
- 1 button (power switch)
- 1 male connector for power supply
- 3 little cables with 2 wires, ended with a connector (like those used in PCs to connect the leds of the front panel to the mother board)
- Electric wire suitable for soldering (thin, malleable, and resistant at the same time)
Once you have got all the components, you can begin the construction of the control circuit. Use the scheme that you can found in the pictures of this step.
SEE PICTURES FROM 20.00 TO 20.14
First of all you must begin by placing the components above the base (or use the same disposition that I have chosen), to realize their actual size. Once you have positioned all the components, you should draw rectangles around them with a pencil to outline their actual space. So, when you re-position them back, you will be sure of their place. This is useful as you have to flip the base for soldering.
I would suggest you to solder the components in this sequence:
1 - Slots for shift register
2 - Resistances of 100 ohms and 1.5 Kohm
3 - Transistors
4 - Connectors
Now, with mooooooooooooooooooore patience, make the connections between the main components. In a second stage, connect each resistor/transistor to the connectors for connecting the cube. Take note of all matches OUTPUT SHIFT REGISTER -> CONNECTORS PIN. This will be essential when we will solder the various wires to each terminal of the cube.
There are several tips that you can follow:
- Cover 3/4 of the perimeter of the base with a track which you connect to the signal mass. It is always useful to have a mass nearby.
- For connections between 2 or more adjacent points use soldering iron to connect directly these points each other
- Do not insist too much with the iron on a single hole of the base, otherwise the pitch copper could fall off.
![Hard Wired LED Cube: [No Programming]](http://img.instructables.com/files/deriv/FTD/SF1T/GO8DC8KW/FTDSF1TGO8DC8KW.SQUARE.jpg)
But Im thinking how let it make easily!
Did this Circuit doesnt need a VCC connection to work?
The only positive volt connection is just on the led, and nowhere else.
the shift register needs vcc too, but Pin 14 is nowhere connected
The single circuit left I do not understand.
Could someone maybe able to explain what that meant?
Thank you
