How to build a 96-Volt Electric Motorcycle
 by Disc Dog
Contest WinnerFeatured
Like many others I decided to quit waiting for a decent electric road bike at a reasonable price, so I built one out of a spare bike I bought off eBay for about $700. I based mine on a '82 Yamaha turbo because 1) I have the ICE version (hence the spare), 2) I like that it is fully faired so it looks 'normal' and 3) it's a shaft drive and one of my main goal was to make it as maintenance free as possible. Shaft drives weigh a lot more and are not as efficient as chain drives, but they are maintenance free. Here is a picture of the finished product. Like Stryker (who built the 72 volt version) I live close to work so distance was not an issue, but speed and performance were, as I have over 3 miles of a rather steep curvy road to go home on. One big thing to consider when doing this is the finished product. Like Stryker I am using AGM sealed lead-acid batteries because of convenience. But since I like the final product so much my goal has always been to upgrade it to some Li-Ion or Ni-MHyd batteries as soon as the become commercially available. It would shave 100 lbs off and give me twice the range, so it's an investment worth making.
Step 1: First, find a donor bike
I have an 1982 Yamaha Turbo. It looks like this. I also had a spare-parts bike (that I bought off eBay for ~$700). It was, for the most part, complete but in pieces.
I decided that I was probably not going to use the spare-parts bike for anything so I stripped it.
Step 2: Strip it and start finding spots for everything
This is what it looks like gutted. I placed the motor in first and located the controller (the electronic carb for the motor). I am using 12-volt, maintenance-free wheelchair batteries; less range but more charges (& maintenance free). I stuck one of the batteries where the original 12-volt battery would normally go.
It is an Advance DC 6.7" 72 volt DC motor (You can run a 72-volt DC motor at 96 volts, you just have to be careful in your rpm-ratio calculations not to over speed it!)
I used a Curtis 72 to 120 VDC, 300 amp Controller (36,000 watts of power available)
Step 3: Connecting the Motor to the Drive shaft
Since the 1982 Turbo is a shaft drive, I had to put a jackshaft and belt drive to turn the drive shaft already on the bike. You really should use a conventional chain-driven bike for conversion. The motor goes in sideways and the drive sprocket just goes right on the motor shaft; much easier (but I already had this bike). Since the drive-shaft to rear wheel was about 2.8:1 ration, I used a 2:1 ratio on the jack-shaft to get an overall ratio of ~6:1. This ratio will be good for mid range power and overall speed, but DC motors have such high-torque at the low end, it will be a bit overpowering for the drive shaft. I turned the controller down to min current and min acceleration.
The only "engineering" part is figuring out where to attach all of the brackets & supports for all of the other components; I used only existing holes on the frame already. It's strictly trial & error.
Step 4: Where to put those batteries!
4 of the 8 batteries went on the sides (replaced the mufflers). I hung them with Uni-Strut channels from where the old side-handles used to be). I'm starting off with the cheapest sealed AGMA lead-acid batteries I could buy. If I like the results I will upgrade them to some high-end lead-acid batteries. When the price is right I'll go NiMh or Li-Io.
Step 5: Putting on the DC/DC converter & Throttle
The rest of the batteries were put on some aluminum angles located above the motor. The DC/DC converter hangs on those angles too. (The DC/DC converter takes the 96 volts used for traction and converts it to 13 volts to run the lights & such. It is the '12 volt' battery for the bike). I just wired the output of the converter to the Main fuse on the fuse box.
The motorcycle's twist grip moves a 0 - 5000 ohm pot-box that tells the controller how fast you want to go & how hard you want to accelerate. It behaves just like a normal throttle.
Step 6: Where to hang the Charger
The charger is designed to be mounted on-board and runs on 110 volts AC (household current). You can get them to run on 220, (and it would charge in 3 hours instead of 6) but it makes it hard to find a place to plug in if you want to 'opportunity charge' at work (or at someone else's house!).
Step 7: Last step
The only other 'major' component is the Main Contactor. It's an electronic 'throw-switch' that connects all of that battery power to the Controller. It is key-switch activated and runs on 12 volts. (I wired it into the Ignition fuse.) I also have it wired in series with the kickstand switch so that after you turn the key-switch you can only drive away with the kickstand up.
Step 8: A snazzy paint job & we are done!
After the snazzy paint job I covered the two sets of saddlebag batteries with half of an ABS tub that Vicki & I found at Lowe's. (Improvising being the key word here!) I put an 'Emergency' Disconnect up on the fairing (just in case something shorted out). It's the bright red knob below the left handle bar grip. I also put a 'Charging Complete' light on the fairing under the throttle grip.
It took me about 2 months of spare time to put it together (and I live on a farm so there is not a lot of spare time available). (Who needs TV anyway? It's over rated!)
Anyhoo, here are the 'specs':
-70mph top speed
-15-20 miles range (I don't baby it at all, so I usually see 15 miles/charge)
-Single speed (including the wheels there are only 6 moving parts)
-Cost to charge: 15 cents
-Can out-accelerate most 4-cyl cars.
-Maintenance: Check the pressure or change the tires every few years.
-Fun Factor: Off the gage.
1-40 of 386Next »
georgeshtc says: Nov 9, 2010. 3:51 AM
hello again mate, just another question about the ev conversion,
motor start and run capacitors are they not required for your conversion?
as you have not included that in your list..
Disc Dog (author) in reply to georgeshtcNov 9, 2010. 5:44 AM
You only need a motor starter/capacitors if you use a single-phase AC motor. DC motors and 3-phase AC motors do not require motor starters. However, a single-phace AC motor will also need an DC/AC inverter (to convert the DC power of the batteries to AC power) and a 3-phase motor does need a motor control inverter (to have variable speed control). Long story short: Use a DC motor and you don't need those things; you only need a DC motor controller.
Ares252 says: Apr 30, 2013. 8:02 PM
you should make a solar charging station :)
trustsushi says: Mar 2, 2013. 9:20 PM
http://oklahomacity.craigslist.org/tls/3651446226.html
would this motor work?
Disc Dog (author) in reply to trustsushiMar 3, 2013. 5:41 AM
I'm afraid not. Two reasons: It's an AC motor and needs an AC controller that runs on DC (battery voltage) which are big and expensive, but the bigger reason is that its only 1/2 a horsepower; not enough ponies to even get a bicycle down the road. You are looking for a DC motor that is rated at 72 volts DC (minimum) and at least 3 or more horsepower. It looks to be a 'big' motor but its not. It's designed to run a bench grinder, that's all.
lawsonrw says: Feb 22, 2013. 6:37 PM
Hello,
Did you use a DC/DC Converter? I see on similar instructables that others are using them, calling it safer. Whats your take?
Disc Dog (author) in reply to lawsonrwFeb 25, 2013. 5:01 PM
I checked; it's on page/step 5.
Disc Dog (author) in reply to lawsonrwFeb 25, 2013. 4:58 PM
Yes, there is a DC/DC converter in there. There has to be to run the 12VDC systems off the 96VDC. Look for it somewhere in this instructable.
Jimichan says: Aug 11, 2010. 2:13 PM
Hey Kentucky-bum; Ever hear of a tri magnum? Google it! Converting your bike to a trike would give you room for a lot more batteries.
Disc Dog (author) in reply to JimichanAug 12, 2010. 5:56 AM
Jimichan, I have heard of them before, and actually helped a buddy build one (gas, about a zillion years ago :-). I had given your suggestion some thought, and I see where Honda has introduced a 3-wheel bike similar to the Bombardiar Spyder, so I suspect that 3-wheel EVs based on that idea are just around the corner. Me, I plan on converting my Toyota Spyder for an 'extended range' EV. I don't mind 20 miles range on my Bike; I only live 5.5 miles from work.
jerhpk in reply to Disc DogOct 3, 2012. 4:37 PM
3 wheeled electrics already exist. Not to hijack, but look into Myers Motors. It's not a traditional trike, but it is a three wheeled electric. rqriley dot com also has plans for sale for the 3 wheeled options (tri magnum already mentioned).
Like the job, just can't do it myself.  I work about 20 miles away, and don't have access to outdoor plugs at either work or home.  find a way to incorporate solar panel charging, and I'll be there!  Will definitely keep this in mind, it's already bookmarked.
npaisnel says: Jan 13, 2009. 5:57 AM
Shame you guys in the USA only use 110 as household for the majority of items. Over here in Europe/UK it is all 240v AC
Disc Dog (author) in reply to npaisnelJan 13, 2009. 6:13 AM
It really is a crime. The only reason they set it up that way was to make money off the consumer. It's less efficient and the hardware needed to move that twice the amps cost more. But most of use have 220 going to the house and garage, so for EVs we can get by on 220 for overnight charging.
FurtherThanTesla in reply to Disc DogJun 1, 2011. 4:35 PM
Saftey is also a major concern. 110v is most often not lethal, while 220/240v is far more deadly. It makes sense that most standard household appliances use a voltage that is safe for people. Ive been shocked a number of times by faulty appliances. If they ran on 240v, I might not be here today.
skylossobaka in reply to FurtherThanTeslaAug 12, 2012. 9:46 AM
220 is a high enough voltage that it throws you back away from the electrocution.
110 is a low enough voltage that it doesn't, allowing the electricity to clamp you to the hot wire.
The choice to go with 220V in most of the world is for exactly this reason - its harder to die accidentally with 220V than 110V.
Nonintuitive, eh?
billiam7787 in reply to FurtherThanTeslaJul 23, 2012. 1:37 AM
its not the volts that are as deadly, as much as its the current, hence why more people than you would think survive lightning strikes.
rjbatc in reply to FurtherThanTeslaMay 5, 2012. 11:59 PM
I got shocked by 220V two times, the first time when I was about 10, the second time about 16, and I am still here, w/o any problems.
lloydrmc in reply to FurtherThanTeslaApr 1, 2012. 12:24 PM
What he said!
wooders says: Apr 19, 2012. 6:43 AM
Guys
I have just seen some battery parts for sale on ebay, Would be pretty easy to make a 96v pack.
http://www.ebay.co.uk/itm/EV-Battery-Pack-Kit-16V-60Ah-Lithium-Phosphate-LiFePo4-Electric-Vehicle-/160785868555?
swordsmen says: Jun 28, 2008. 12:44 PM
Why don’t you use boat batteries instead of wheelchair batteries? Boat batteries can be recharged like wheelchair batteries and they hold more power.
ac-dc in reply to swordsmenJan 19, 2012. 1:47 PM
Given same battery tech, what it is used for and called is fairly irrelevant, they are basically different battery sizes or different plate thickness to arrive at different capacity.
Similarly you can buy a thick plate (deep discharge) battery in a wide range of sizes regardless of what they are called, though it is often the case that the most popular sizes used cost less.
kagenin in reply to swordsmenAug 19, 2009. 8:37 PM
I'd imagine that lifespan is an issue. Boat batteries may hold more power, but you won't be able to recharge them as many times as a wheelchair battery before they'll stop holding a decent charge. I would imagine that wheelchair batteries are designed to be as hassle-free as possible (since a disabled person in a wheelchair probably won't be able to do most maintenance of their own chair), while basic boat maintenance requires you to check your batteries on a regular basis anyway. But I'm not 100% sure about these statements, it's just conjecture on my part.
Disc Dog (author) in reply to kageninAug 20, 2009. 5:31 AM
Kagenin, Most large, industrial deep-cycle batteries are lead-acid, but not sealed; they are what is commonly referred to as 'flooded'. On average they deliver about 30% more power than a sealed lead-acid battery but require routine maintenance. You must check the water level in them regularly or they die a premature death. But contrary to what you said, you also get about 30% more charges out of flooded batteries (vs. SLAs). I chose SLAs (sealed lead acid) because of the lack of maintenance knowing full well that they will not go as far, nor last as long, as flooded batteries. (The price of being lazy :-)
kagenin in reply to Disc DogAug 20, 2009. 9:31 AM
Ah, thanks for clarifying.
ThorsMitersaw says: Dec 12, 2011. 7:44 PM
If this is a direct drive, that means you can not coast, correct? And that high speed will always equate to high rpms?
Disc Dog (author) in reply to ThorsMitersawDec 12, 2011. 8:41 PM
You can coast, but it's like letting off the throttle with a gas engine with a manual transmission only no compression to slow you down. The electric engine just free spins. And, yep, if it goes more than 70 mph you run the risk of over speeding the motor beyond its rated rpm.
ThorsMitersaw in reply to Disc DogDec 13, 2011. 10:18 AM
Would/could it be practical to incorporate the/a transmission of some sort to operate within a wider band?
Disc Dog (author) in reply to ThorsMitersawDec 14, 2011. 1:09 PM
One of the distinct advantages of electric motors over ICE is that the power band is much wider over the operating RPM range. In other words you only really need additional gears to get over 60 in a hurry. But that also means you need additional horsepower--it takes twice as much hp to go from 55 to 70. I don't have that much hp in my bike. Just enough to get it to 55 in a hurry and 65 with a bit of a delay.
Additional gears also mean additional weight and complexity too. Most productions EVs (Leaf, Focus, EV1...) only had one gear. As a matter of fact, the EV1 was the fastest production car GM had ever made up to its demise in 1995; it could go 183 mph on one gear...but it also had a 20,000 rpm motor :)
ThorsMitersaw in reply to ThorsMitersawDec 13, 2011. 10:19 AM
also, nice choice of bike. never seen this thing before and thought it was pretty fitting. looks vaguely 80's japanese anime scifi
Disc Dog (author) in reply to ThorsMitersawDec 14, 2011. 1:11 PM
The '82 Seca Turbo was kind of the first of the 'Star Wars' design with full body fairings...another reason I chose it :)
v_peter says: Nov 23, 2011. 10:20 PM
Hi! I don't have anything against an eletric bike. But please tell me that this isn't real. You didn't took one of the rarest bikes from Yamaha? To remove the most special thing, the early motorbike turbo???
Disc Dog (author) in reply to v_peterNov 24, 2011. 4:47 PM
Hey, I kept my other Seca Turbo alive, didn't I :)
li789 says: Mar 4, 2011. 2:46 PM
what happens when you drive it say thru a puddle? would it shorten out?
wmacdougall in reply to li789Nov 9, 2011. 9:30 AM
It would depend if he sealed the circuitry (or any electric current running through) or not.
dharampal says: Oct 31, 2011. 8:39 AM
hey, wanna if we can use dc motor as generator for ebike and can help to charge batteries by pedalling the bike and then using battery power for running the motor
bjforesthowell says: Oct 2, 2011. 11:27 PM
I'm looking to make my conversion on a Honda Zoomer, and I've been all over the web looking for motors. Where did you manage to pick yours up?
Disc Dog (author) in reply to bjforesthowellOct 18, 2011. 7:23 AM
[Sorry about the delay for the response; I've been out of country for the last few weeks.] I had mine laying around from an auction I had gone too a long, long time ago. You can pick them up on ebay every so often, but if you just do a search for 'used DC electric motor' you can chase a few sites that offer them. You can also pick them up new on the net at places like this: http://www.evolveelectrics.com/index.html
vinyard says: Aug 23, 2011. 7:42 AM
I apologize for the question as I am sure the information is here somewhere. For the life of me I cannot find it. What is the range and top speed of this bike? There is a new electric bikes by Brammo that costs $9000 with a 80 mile range and goes 100 mphs. To get the same specs do you think you would end up spending about the same amount of money? Thank you.
Disc Dog (author) in reply to vinyardAug 23, 2011. 8:04 PM
My bike is DC powered, the Brammo is AC powered that's why it is faster. I think. to get the same specs you would end up spending that much. If you have $9K to spend buy the bike.
pineapplenewton says: Jun 13, 2011. 7:00 PM
Hey, i hope this hasn't been asked but, i am going to do a conversion with this same model of bike and i was wondering if using a love joy typed coupler would work to connect the drive shaft to the motor instead of the belt system you have.
1-40 of 386Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
