3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a 96-Volt Electric Motorcycle
Step 2Strip it and start finding spots for everything
This is what it looks like gutted. I placed the motor in first and located the controller (the electronic carb for the motor). I am using 12-volt, maintenance-free wheelchair batteries; less range but more charges (& maintenance free). I stuck one of the batteries where the original 12-volt battery would normally go.
It is an Advance DC 6.7" 72 volt DC motor (You can run a 72-volt DC motor at 96 volts, you just have to be careful in your rpm-ratio calculations not to over speed it!)
I used a Curtis 72 to 120 VDC, 300 amp Controller (36,000 watts of power available)
8 comments
Jun 28, 2008. 12:44 PMswordsmen says:
Why don’t you use boat batteries instead of wheelchair batteries? Boat batteries can be recharged like wheelchair batteries and they hold more power.
Jan 19, 2012. 1:47 PMac-dc says:
Given same battery tech, what it is used for and called is fairly irrelevant, they are basically different battery sizes or different plate thickness to arrive at different capacity.
Similarly you can buy a thick plate (deep discharge) battery in a wide range of sizes regardless of what they are called, though it is often the case that the most popular sizes used cost less.
Aug 19, 2009. 8:37 PMkagenin says:
I'd imagine that lifespan is an issue. Boat batteries may hold more power, but you won't be able to recharge them as many times as a wheelchair battery before they'll stop holding a decent charge. I would imagine that wheelchair batteries are designed to be as hassle-free as possible (since a disabled person in a wheelchair probably won't be able to do most maintenance of their own chair), while basic boat maintenance requires you to check your batteries on a regular basis anyway. But I'm not 100% sure about these statements, it's just conjecture on my part.
Aug 20, 2009. 9:31 AMkagenin says:
Ah, thanks for clarifying.
Jun 29, 2008. 7:55 PMMontreal says:
evparts.com Controller is 1400$ :S Motor 989$ Nice idea, but definitly not a cheap project ! If the project could be done for 1000-1500$, that would be so cool.
Feb 5, 2009. 9:50 AMthebluecommander says:
I think it can be done. Honestly, a Etek-R motor with controller and batteries can be done for $1500. Nice. check out Robotmarketplace
But I haven't done this myself.
Jun 26, 2008. 6:11 AMJosh_B says:
(removed by author or community request)
Jun 26, 2008. 6:44 AMzach911 says:
motorcysles ehh....
Jun 26, 2008. 8:35 AMJosh_B says:
Doh! My mental spell-checker must have taken a coffee break :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:Kentucky-bum(EV World)
A jack of all trades and a master of many; I was the Sr R&D Engineer and Manager of R&D for a very large company, but now I am consutling on my own. I can truly say 'been there, done that', but I can...
more »
