3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a 96-Volt Electric Motorcycle
Step 5Putting on the DC/DC converter & Throttle
The rest of the batteries were put on some aluminum angles located above the motor. The DC/DC converter hangs on those angles too. (The DC/DC converter takes the 96 volts used for traction and converts it to 13 volts to run the lights & such. It is the '12 volt' battery for the bike). I just wired the output of the converter to the Main fuse on the fuse box.
The motorcycle's twist grip moves a 0 - 5000 ohm pot-box that tells the controller how fast you want to go & how hard you want to accelerate. It behaves just like a normal throttle.
4 comments
May 2, 2009. 6:22 PMDragan226 says:
It is because of this awesome Instructable that I started doing my own EV with a Suzuki Gs 750 E, Thanks Mike! Instead of using a DC-DC converter, I thought just to plug the batteries in series for the motor and in parallel for the 12v parts and to charge them with a high amp 12v charger. I think that this would work, do you think it will? Thanks -Dragan
Nov 9, 2008. 5:55 PMjoeybolz says:
Nice job, like it. Found this while scrolling around on e-bay and saw your gas one for sale. Now I am interested in doing my own. Why do you need a DC to DC converter for your controls when you can pick 12 off of one battery? Has anyone used industrial DC drives instead of those Curtis's. 90's vintage DC drives can be had cheap.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:Kentucky-bum(EV World)
A jack of all trades and a master of many; I was the Sr R&D Engineer and Manager of R&D for a very large company, but now I am consutling on my own. I can truly say 'been there, done that', but I can...
more »
