This instructable has been removed by the author.
55
comments
Add Comment
| 1-50 of 55 | next » |
i have bamboo growing in my back yard and the biggest diameter i have is 1 11/32" do you think that is thick enough to support me for top and dow tube? i am 6'1" and weigh about 220. Thanks a bunch your second bike looks very much like a Calfee. Great Work.
Would what you have hold you and not break? probably. Would it be ideal? It really depends on the type of bike you are building, and the type of riding it is intended for. It is a fixie (single speed), for milling about at the coffee shoppe, or comuting, it'd probably work out wonderfully, and be a nice plush and even springy ride. If you are going racing, unless you are growing solid cane, iron bamboo, look for something else. What you have, in that small a diameter, will be too flexy at your height and weight. You're going to need a minumum of a 58cm frame and the tubes will just be too long to be stiff at that diameter.
Bought my bamboo today! Anxious to get started. Thanks for the great instructable to guide me.
I appologize in advance as this answer may be long winded... The bamboo shrinks alot during torching to color. But, this most recent batch was VERY WET! It was still quite heavy ,even after heat treating, but has reduced it's weight tremendously over the last 5 or so weeks. I think letting the bamboo dry, even after torching is a good idea, depending on how wet the bamboo is. Possibly even cooking or smoking the bamboo after torching could be a good idea. The bamboo doesn't shrink much though, at all, once it's been torch treated. I'm always looking at other ways to make sure the bamboo doesn't split during the process of construction and then during it's life. I purchase newly cut green bamboo. Last summer when it was 110 degrees outside, I left the bamboo outside and it dried very quickly, within 3 weeks. That, along with the torch, was the best batch I've had. I heat about 4-5 bikes worth at a time, so it doesn't all get used at the same time. Most sits at least 6 weeks, I've had several pieces sitting for 14 months. It takes me about 4-5 weeks to build a bike. I think this next batch I do, I will bake in a smoker for several hours at around 180 degrees, then torch for color. I'm also going to try some different types of bamboo, to see how the processing affects the different species. holding up to crush forces on the tubes is important to me. I want light, but I also want strong and rigid. WIth rigidity and strength being most important and light, quite important. A lot depends on how old the bambooo is when it's harvested, what time of year (wet season, dry season) it's harvested, and the species. Bamboo must be at least 2 years old to gain it's full strength potential and older is better, as much as 5 years or more.
As I start my business, I will be trying to find a source that will harvest the cane, and kiln dry it and smoke it before shipping. I think this is the absolute best option. It would also be nice to have it cleaned out from the inside, to a specific thickness. All this working would assure the bamboo that made it to me was solid, clean, and split free. But, for the home builder, the information above would suit well enough. If your bamboo feels heavy after heat treating let it sit a couple of weeks and see if it gets lighter (weight). If it does, then it's not totally dry. Wait a bit before building.
I hope this helps.
Resin - A good resin is key to this project. I used this - Max CLR - hp - from these guys (also on ebay) http://myworld.ebay.com/polymerproducts/ Here again - I probably used about 1/4 gallon resin/hardner on "Project Uno" - but much of it, perhaps as much as half, was wasted.
Small Parts - Nova Cycle Supply is perfect for things like cable stops, brake bridges, etc. If you're gonna start with no frame and just want bottom bracket, head tube and dropouts, these guys are great too. I ordered from them and had my stuff in 2 days! http://www.cycle-frames.com/bicycle-frame-tubing/BRAZONS-SMALL-PARTS/
Just got my bamboo in the mail today and already started testing on my first piece. Thanks for the great write up. Should be an interesting winter project.
Carbon fiber ordered, getting Epoxy locally and can't wait to take the next steps.
Best of luck to you, have fun with it. I keep saying I'm going to start # 2 here soon, but I keep putting it off. This time, since I know about this site now, I'll take many more photos and do a better job with the description as I move along. Last time the instructible came after the fact, so I tried my best to go through the photos I'd taken to make something out of it. Have a great day, and thank you for the compliment!
User name on Ebay is c17482y
This guy. Don't know if they still have any. Wouldn't hurt to ask?
As for your frame jig idea. Yes, it proably is the best idea, "IF" you have the tools and the know how. I also say yes to the jig, if you're building from scratch. In fact I don't see any possible other way. For my first project I had speed and simplicity in mind. For my next build I am doing the same. As I get more proficient in the practice, I will probably construct a jig and just purchase a threaded aluminum head tube and bottom bracket. But again my first project was just an excercize in "can I really do this"???
As for the bamboo size - here's where I am lacking a bit in my expertise. I know there are several species of bamboo. I ordered the bamboo from a gal who stated her bamboo was thick and strong. When it arrived, it was in fact thick and strong - I got lucky, I guess. Walls are about 6mm thick and the tubes are various diameters. I actually specified the diameters I wanted the tubes to be. I wanted something near the diameters of the original bike I had cut apart. On this new bike I'm just using left over bamboo from the first project. I'll check into the species she sent me, as I think it good stuff to work with - very light once dried and quite strong.
It is a very rewarding project. Best of luck, and if you need any additional questions answered ask away....
I've got almost 1000 feet on it, and yours looks a LOT more like what I'd like mine to resemble.
http://www.kepfeltolto.net/users.php?act=user_gallery&gal=Kobike
http://www.bikeforest.com/CAD/index.php#
You are absolutely right, this is a wonderful feeling to ride a bike you made your own.
http://picasaweb.google.com/bamboobikeboy/BAMBOOBIKE?feat=directlink
I hope it helps to make your own if needed.
Well done - a good first instructable.
