3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a Bamboo Bicycle or bike
This instructable has been removed by the author.
55 comments
1-50 of 55next »
Aug 18, 2010. 8:33 PMitzjack says:
after looking at this i was so inspired i chose to do it for my senior project! im really low on money haha so i was curious about how much it cost you to make the bike altogether.
May 5, 2010. 10:19 AMmagicalnumber12 says:
 Hey i was wondering what diameter of bamboo did you use on either this bike or your second bike. Top Tube, Down Tube, Seat Tube, And Seat Stays?
i have bamboo growing in my back yard and the biggest diameter i have is 1 11/32" do you think that is thick enough to support me for top and dow tube? i am 6'1" and weigh about 220. Thanks a bunch your second bike looks very much like a Calfee. Great Work.
May 7, 2010. 7:07 PMmagicalnumber12 says:
 i actually ride a 56cm frame. i have short legs. i have been sized 56 is right for me. and sounds good thank you very much. will post pics when i get going.
Jul 11, 2010. 3:43 PMmagicalnumber12 says:
So i just went in my yard with a caliper and found the stalk of bamboo i am going to use. The bamboo grew quite a bit in the last couple of months. i found a stalk that is 1 4/5" in diameter for the top and down tube. i am super excited to get started.
May 17, 2010. 5:16 PMCxXxC says:
one question can you build a dirt jumping/ freeride bike with this methood (would it be strong enough)
May 8, 2010. 6:51 PMkentdvm says:
 Fantastic!  Great job on putting it all together.  I'm getting ready to start my bike and I had a question about curing/drying time for the bamboo.  Was the bamboo freshly cut when you received it?  Did you simply heat green bamboo for color and then use it?  The reason I ask is I've read where someone said you need to let it cure for 6-8 weeks after heat treating.  With the color you attained, I can't imagine it needs to dry more.  You have noticed any shrinkage of the bamboo from drying since you build it?
Bought my bamboo today!  Anxious to get started.  Thanks for the great instructable to guide me.
May 9, 2010. 4:56 AMkentdvm says:
 Great insight.  Thank you!  Going to go get started this morning.
Dec 6, 2009. 6:41 AMclisnek says:
 where did you get the carbon fiber string and the resin and anything else you need besides the aluminum frame and the bamboo
Nov 17, 2009. 7:59 PMxtracycletony says:
Has anyone consider bolting the bamboo to the inner steel frame before covering the joints with hemp/carbon fiber?  Just wondering if there is a simple answer as to why this wouldn't be a good idea before I try.
Just got my bamboo in the mail today and already started testing on my first piece.  Thanks for the great write up.  Should be an interesting winter project.
Nov 20, 2009. 5:45 PMxtracycletony says:
OK, I've been heat treating my Bamboo and your info has been a great help.  I do have a question.  I noticed some of my smaller diameter bamboo fits snugly inside my steel tubes I cut out.  Would it be possible to slide bamboo about 1 inch diameter into the existing metal at the head tube and BB and Carbon fiber tie it all together?  IE, would the 1 inch diameter bamboo be too shin to use I guess it what I am trying to say.
Carbon fiber ordered, getting Epoxy locally and can't wait to take the next steps.
Nov 22, 2009. 3:10 PMxtracycletony says:
WOW, I wonder how they can make that strong enough without some sort of additional material.  I hope someone in my area shells out the dough for one so I can test it :)  We will see how mine comes out, moving forward.  Thanks for the advice.  This is going to be a 2 mile commuter bike and causal speed.  Thinking 3 speed internal with roller brake.
Oct 27, 2009. 6:20 PMsarliaee says:
thanks ericstevens73, you are a legend, by far the most informative bamboo bike instructable around. i can't wait to build one, you've given me that nice good happy feeling inside.
Sep 27, 2009. 6:28 PMjustin1612 says:
where did you buy the carbon string from?
Sep 14, 2009. 5:36 AMimmigrantul says:
Hi, And congratulations for this achievement!I want to build one myself but right now I am gathering info since is going to be my first try.I have a welding shop so I intend do build the jig by the frame of the bike I am going to cut.Is this a good idea or,I should do it diferent?And one question about the bamboo is what sisez are the rods?Can you tell me how thick they should be?Thank you,I hope in spring I will enjoy a ride on a bamboo bike.
Sep 9, 2009. 11:38 AMcheshirecat1975 says:
This is gorgeous! I love the wrap job with the Carbon Fiber tow. Any idea roughly what length of tow you used? I'm still working on my bamboo bike at: http://jamesjessup.com/blog/category/bamboobikeblog/
I've got almost 1000 feet on it, and yours looks a LOT more like what I'd like mine to resemble.
Aug 22, 2009. 5:43 PMKoboldka says:
Congratulation, very nice job. I also made one bamboo bike, so I know what a time consuming thing is to do it... Here are some pictures of my beauty:
http://www.kepfeltolto.net/users.php?act=user_gallery&gal=Kobike
Aug 27, 2009. 11:27 AMKoboldka says:
My reasons to use the PU foam:<br/>1. it increases the rigidity<br/>2. It absorbs the vibration<br/>3. It keeps the moisture out<br/>I'm nut sure these are thrue, but I belive so.<br/><br/>The wrap material I used is the same as the blumbers used in the past (or still?) to seal the threads. Its name is "oakum" or "tow" in English. It is simple hemp fiber, looks like a human hair.<br/>I think Calfee uses similar, just refines at the end:<br/><a rel="nofollow" href="http://www.calfeedesign.com/bamboo.htm">http://www.calfeedesign.com/bamboo.htm</a><br/>
Aug 23, 2009. 6:05 AMKoboldka says:
The method was similar, but not the same. I cutted an old CrMo trekking frame, used its fork, rear drop out, and joints at head tube and BB. There is no metal joint at the connection of top tube and seat tube, just a 10cm metal tube glued inside the bamboo (and reinforced with carbon from outside). I made a frame jig to fix the tubes correcly. As it was a trekking bike and I wanted a fixed gear I had to change the geometry (higher BB needed), additionaly I wanted to have a bike what is exactly fits to my size. This site helped me to design:
http://www.bikeforest.com/CAD/index.php#
You are absolutely right, this is a wonderful feeling to ride a bike you made your own.
Aug 26, 2009. 5:55 AMKoboldka says:
I used a very simple jig, I uploded lot of photos to here:
http://picasaweb.google.com/bamboobikeboy/BAMBOOBIKE?feat=directlink
I hope it helps to make your own if needed.
Aug 18, 2009. 3:46 PMmmihevc says:
Very nice. The finish looks fantastic. I've wondered about using a clear marine finish on bamboo. I wonder if this type of finish would protect the wood especially from UV and water. On the other hand, it might stop the bamboo from breathing. Dunno. Anyway, very nice job. I appreciated all the pictures.
Aug 19, 2009. 3:52 AMLftndbt says:
I sell a few ornimental bamboo products. The ones for exterior use state, "Apply an exterior varnish, after sanding the bamboo". I believe you should rub the "shine" back off the bamboo, before sealing. I don't think it will bind to, the shiny surface. Hope that helps.
Aug 17, 2009. 10:11 PMANDY! says:
wow. hows the weight?
Aug 17, 2009. 7:16 PM1tri2god says:
Excellent job on the write-up and the bike, Eric!!!!! If you ever find yourself in NYC and want to build another bike, c'mon over to Brooklyn! I put my bamboo buildups in a vacuum chamber to get the micro-bubbles out of the resin (important little tricks from my build-up days in Indy for the formula cars;). Makes the joints much, much stronger and an important hint to why a bamboo bike can be guaranteed for 10 years!!! Top quality job on your bike, all around!
Aug 17, 2009. 6:57 AMjeff-o says:
So uh... Can we see some pictures or something?
Aug 17, 2009. 2:17 PMjeff-o says:
Great, thanks! It looks excellent.
Aug 17, 2009. 1:28 PMKiteman says:
That is a pretty bike. Did you not think of trying to make bamboo handlebars as well?
Well done - a good first instructable.
1-50 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:BAMBOOBIKER
